UNIQUE ID FOR PROTEK 9750 HD IS IT IN BOX?
  • ebmitie
    • 94
    Thinking of getting this box but from a german shop, however I read I need an UNIGUE ID to get box hooked up properly. Is this unigue ID in the box or must I buy from an approved seller?
    ebmitie
  • mdt
    • 3034
    ebmitie
    hi,the 9700/9750 does not need a id file although it will need to be flashed with sw for it to clear the packages. the unique id file is used on the prokek unixbox (dm500s clone) and for the nanoxx/protek 9600ip(sd) when used in conjunction with sw 29e or 29t for reception of n*** on hotbird and jsc/add on nilesat. regards mdt
    • ebmitie
      • 94
      many thanks for explanation. I am just learning and I just emailed a seller and asked about unique ID and they replied Yes it comes with ID!!
      I have read so many bits over last few days I am trying to recall where I saw it mentioned and as you say it probably referred to the 9600.
      Its a lot cheaper from germany as well!!
      ebmitie
      • ebmitie
        • 94
        Can I just confirm I buy box and then flash it to make it work as it should?
        ebmitie
        • mdt
          • 3034
          ebmitie
          yes m8, regards mdt
          • bonif
            • Mar 2009
            hi to every body
            please help i just got a protek 9750hd ip but i realy don't have a clue what to do to make it work.
            and how to poceded.
            tanks in advance forany advice
            • mdt
              • 3034
              Originally posted by bonif
              hi to every body
              and how to poceded.
              firstly you need to extract the software file ive posted then put the file onto a FAT32 formatted usb stick making sure the file goes into the ROOT folder. now press.. MENU/SYSTEM INFO/FIRMWARE UPGRADE/OK... after the upgrade is finished your box will re-boot. when you have scanned your channels in and enabled your network(use dchp or static) you can get the bouquet lists by pressing OK then BLUE button. if you make sure the auto-update is set to on then the stb will update itself when future firmware is released. regards mdt
              credit to @troya for the howto
              • hudo81
                • Aug 2011
                new to this
                Hi Guys i am new to this satellite lark, i have purchased a Protek 9750 with a 1meter motorised dish.
                i am planning to install this weekend, are they any pitfalls i should beaware of beforei start?
                Cheers
                • mojocvh
                  • Aug 2011
                  @hudo81
                  Same here could do with some confidence boosting advice!
                  cheers
                  Mo.
                  • jud1255
                    • 34
                    watching with interest
                    does anybody sell these with the automtically updating software already included, eg plug n play
                    thanks jud
                    • badapple
                      • 2041
                      thanks jud
                      Normally a business seller will sell box with FTA firmware installed.(private sellers may update)
                      Updating the firmware is really easy, new models use a USB pen & a press of a few buttons and you're done, Once updated, the box will auto update to latest firmware as long as you are connected to net.
                      Latest firmware & how to available on dedicated site.
                      SLOWLY, OUR FREEDOM IS BEING ERASED.
                      SOON, WE WILL JUST BE A NUMBER.
                      IF WE DON'T FOLLOW, WE WILL BE ERASED.
                      • reggiie
                        • Jul 2011
                        • 29
                        I am ready to order a protek hd asap just dont fancy splashing out ?240 + 100 for dish without knowing someone who owns one of these. I have been researching for a while now and would just like to know if it is true when their is to many people on the server freezes up and if anyone currently has a protek hd is the football all good for this season. thanks
                        • jud1255
                          • 34
                          already looks like its been updated to Protek MK-1 HDTV,
                          im after fully updating twin tuner dvbs2 and dvb t and ideally pvr same as my ipbox 9000
                          • mtv1
                            The Stig PT
                            • 4413
                            badapple the guy above you has one 9600IP NanoXX-Protek-Funbox, 9700/9750HD Protek, Unix500, MK-I this tells you what servers are up
                            • bj1
                              • 445
                              i use the protek 9600ip not hd and have plenty of epl footie and films to watch but if you are buying the hd version you get even more sats and channels to choose from, and with the team that supports the protek server are exellent..... there has been some problems with nova sports and is now running with sports 1&2 of wich shows epl..... BJ1
