UNIQUE ID FOR PROTEK 9750 HD IS IT IN BOX?
cheers im already there
looks very interesting, i just dont want to do same as when i bought the cuberevo 9000hd
its been really hard work on my own manages to flash images and channel list editing but when i installed enigma come to a brick wall.
Would the servers be preinstalled if i bought a new one as this is where i was stuckComment
protek boxs come with fta software installed but once the software is installed the box has a auto-update facillity that recieves updates when needed. the 9600ip requires a patch lead, loader and sw to update for the first time but the 9700/9710 or 9750/9760 are very easy and take 5 mins to flash with a usb stick. the protek mk-1 is very new and runs on e2 which as you know is a little more difficult to run but still uses the usb to flash first time ect. the protek requires a full-time stable bb connection but the dark forces have a excellent record and i myself can recommend them. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
no m8 use this. regards mdtAttached FilesDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
you need to scan the satellites in then press.. ok then blue to give you the package lists for channels that clear. look at 42e/23.5e/19.2e/16e/13e/9e/7e and 30w for the packages. there are 1 or 2 packages on 7w but this sat needs a huge dish for reliable reception in the uk. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Hi mdt,
Loaded your patch V1.12, worked a treat,
everything 100% OK, over a 100 channels
open on the three Sat I have scanned
in (13e 19e 23.5e).
The Protek does ask if you would like
to upload a Channel list by USB stick.
Will look around for a good Channel list.
Thank again for all your Help BF.Comment
Protek 9600 IP dead.
It seems like the old Protek 9600 IP is dead. Only those with a unique ID and th HD versions are still working.... and nobody would tell us how to get this unique ID!!!Protek 9600 IP BT 1.34 SW T75 K67 working without ID
Maxx 10000 BT 1.34 SW T75 K67
Protek 9760HD_IP FW 1.13 HW 1.2 Key 0.1.98xComment
