Hi. I have installed lots of TM2600 motors and the way they works is as follows:
a) The motor has a dial like a timer. It has 0 in the middle and 1 to 70 on either side of the 0. The figures go up in steps of 10 ie 10 20 30 etc. These figures are used by USALS to locate the satellites at their given positions. For example when you tell USALS to go to 30 west it will move the dial and stop when it reaches 30 on the dial.The west satellites are to the left of the 0 ie anti clockwise and the east satellites are to the right of the 0 ie clockwise. When you are going east the dish will move to the left and when you are going west the dish will move to the right.
b) USALS uses your postcode figures to know which way to move your dish, for London it is 00.1W and 51.5N .
c) Also remember that USALS will only go to a satellite position as indicated in your menu. So make sure that all satellites you wish to pick up have the correct positions set.
d) A common problem for most people is that when they search for a satellite they dont have the correct TP ( or frequency). Always make sure you have a valid TP or channel for any satellite otherwise you will never find it.
e) It does not matter which satellite you look for first, the important thing is to find a satellite and then you can work out from there where you are. I always find that the satellites at 13 east, 19.2 east and 28.2 east are best to start with for the UK because they are so powerful and easier to locate and they are next door to each other. In reality all satellites are next door to each other
f) The way to find a satellite is simple ie do what i do. Make sure all cables are connected correctly and you have a green light on the motor. Using USALS set the motor to 0 by selecting GO TO REFERENCE in your motor menu. This will centralize the motor ie at point 0. If you have the dish already mounted on the motor tail make sure it is facing straight ahead and roughly central on the tail.Make sure dish is not pointing up or down but straight ahead. This way you will have motor and dish centralized at 0. Using USALS send the dish to a satellite ,in my case 28.2 . You can do this in two ways either from your SAT button on remote or using the GO TO option in motor menu. The dish should now move to the left heading for 28.2 east. When it reaches 28.2 the motor and dish will stop. Now comes the fun. Set the motor setting from USALS to OFF ( this will stop the motor from accidently moving when you exit the menus). Now select channel BBC 1 LONDON or TP 10.773H s/r 22000 Now loosen the dish a little to allow you to move it left or right. Move the dish slowly a bit at a time left and right until you get either a picture from BBC1 or the signal in your TP menu. When you get a perfect picture or strong signal then tighten the dish up. We now have our first satellite under USALS and can look for others. Set motor setting back to USALS and send it to another satellite ie 5 west. Allow dish to move to 5 west and when it stops fine tune the dish slightly until you get a picture or TP.When you get 5 west perfect then send dish back to 28.2 to see if signal is still ok. Remember you may need to fine tune the dish several times until you find the right setting for the arc. Take time and patience and you will get there . Please let us know if this has helped you a little or if you have any queries. Regards.
