The problem with buying a DU clone, is their is not a lot of money difference between that and the original if using good components. The only way is to use cheaper components. The original DM800 were excessively over priced, so the chances of a good cheaper clone is a good one. If someone is after a DU it would be better to look for a original second hand or refurbished unit.
Nextbay = Thieves
I have to disagree. I've used them many times and found the service and customer service to be very good. Did you remember to pay dhl the excise duty when they asked for it cause that's the quickest way not to receive your goods. This means you need to use a valid telephone number so they can contact you and not just one you have made up.Comment
Same luck as I've had on many occasions. It seems the service is no worse than buying from any other overseas company. In fact there are more horror stories with amazon than nextbayComment
PAYPAL
