dish settings
  • ramjet
    • 2995
    #16
    it could be that there are problems with the installation, or its somehow been setup for spanish channels , but I doubt it
    if it says the transponder already exists , then you cannot add it
    in which case select the group first as 19e , then go into the menu and installation - channel search , change to manual scan from auto scan , press ok on the first transponder which on mine is 10788 , and select 12226 and below it you should see 27500 and H , and all channels and off
    now press the red button and scan , and save
    I believe its your newbieness and not knowing your box or how this works that is holding you back, rather than blame the satellite installation put in by professionals
    • ramjet
      • 2995
      #17
      if you are still having problems , back up your current list to a folder on a fat32 formatted usb stick
      then load this one as I have manually scanned in those transponders and the FTA channels are opening ok , especially those news channels
      its zipped up so unpack it first with winzip , winrar or 7zip
      it also has the 28e channels on it too , recently updated I might add
      so it has 28.2e and 19e
      this will tell you if the system works or not, if it does and you can see them , then your scanning techniques need improving
      • mikejc01
        • Sep 2011
        • 82
        #18
        Thanks ramjet ,it could be me not kowing the ins and outs of things.
        I will try your list and see what happens buddy ,when I have done the above it also says moving to 19.2 astrra 1 ,I will give it another bash very soon
        • ramjet
          • 2995
          #19
          I will try your list and see what happens buddy ,when I have done the above it also says moving to 19.2 astra 1 ,I will give it another bash very soon
          that is because if you check out your first post you have usals set , and yet you have no motor, so clearly you have not disabled the motorised dish setting (turn it to OFF) in favour of either a fixed dish setup or in favour of diseqc 1.0 or 1.1
          not setting it up correctly in the first place can only add to your woes
          and just to clarify, is this dish system at your flats only set for 19.2e ? , or can it also access anything else like 13e hotbird or 28.2e astra 2 ? or hispasat at 30w ?
          if its fixed on 19 east then just set motor to OFF and the diseqc settings do not matter as you have no switch involved
          EDIT
          if its a fixed dish on 19e only, you should have this
          dish setting on blade bm 7000 are
          1 Satellite 19.2 ASTRA 1
          2 Frequency 10.787 ghz(V)
          3 lnb power ON
          4 lnb type Universal
          5 lnb freq 9.750/10.600
          6 22khz auto
          7 diseqc 1.0/1.1 OFF/OFF
          8 diseqc motor OFF
          9 go to - press OK
          • mikejc01
            • Sep 2011
            • 82
            #20
            I think it would be a fixed dish ,cant get to the roof to check it out .
            for now I will turn it to off
            • mikejc01
              • Sep 2011
              • 82
              #21
              Hi ramjet,
              just tried your 19.2 list channels
              4-6 scrambled
              7-8 no video -audio
              10-17 scrambled
              28-31 no or bad signal
              32-64 test pages guia etc
              65-102 no or bad signal
              112-137 no or bad signal
              3 lnb power ON
              6 22khz auto
              8 diseqc motor OFF
              9 go to - press OK
              its set like this
              • mdt
                • 3034
                #22
                Hi ramjet,
                4-6 scrambled
                7-8 no video -audio
                10-17 scrambled
                3 lnb power ON
                6 22khz auto
                8 diseqc motor OFF
                9 go to - press OK
                its set like this
                can you find out if anyone else in your block is receiving any other channels above 11.700ghz as this would tell you if its down to the lnb/l.o.s. settings. maybe the distrobution amp is only sending 10.700 to 11.700 down the coax as the spanish channels are all between these frequencys,regards mdt
                • mikejc01
                  • Sep 2011
                  • 82
                  #23
                  I dont know that many onlyy to say hello etc in this block all are spanish apart from a few who dont have sat tv .
                  If I had my own dish that would solve the problems am sure
                  cheers buddy for your help and advice
                  • ramjet
                    • 2995
                    #24
                    Hi ramjet,
                    4-6 scrambled
                    7-8 no video -audio
                    10-17 scrambled
                    3 lnb power ON
                    6 22khz auto
                    8 diseqc motor OFF
                    9 go to - press OK
                    its set like this
                    I did not test all of these channels , my POINT weas that I checked the fta news channels like sly news , france 24 english and euronews , as well as a few others
                    so assuming you failed to get them, you have a problem locally , what that is I have no idea, but it has to be something to do with not having your own dedicated dish and lnb
                    all I can say is that those fta channels on those transponders I listed work here in the uk on a motorised dish, and probably work for 99% of the other enthusiasts too
                    so houston , you have a problem , locally , so solve it
                    • mikejc01
                      • Sep 2011
                      • 82
                      #25
                      I need to get my own dish then I think ramjet
