Is this the End or The End is Nigh
This topic is closed.
  • phoneman786
    • 21
    #151
    dm500 glitching
    dream serious glitching for 2 weeks. last 2 days every minute. any fix? thx
    own setups no complaints
    other servers complaints
    • the man
      • 1660
      #152
      Same line , dm500s fine. Blade real bad , very odd there testting someting,
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        #153
        800 fine, openbox fine 500s fine.
        Sent from my Motorola Colorado using magic.
        • Rodbouy
          • Jul 2010
          • 1320
          #154
          try using newcamd on the blade.
          • satsmo
            • 6397
            #155
            Originally posted by Manic01
            1) no
            2) I have been involved in satellite forums for may years, helping run them etc and stand by what I say. the eurovox cable brigade invaded the sat section for plug n play sat tv for sky uk but all the main receivers are bought for most other sats.
            Despite what I posted on this thread only a few pages back http://www.digital-kaos.co.uk/forums....php?p=1807928 the next time I see mention of that specific UK provider from anyone there will be a one month ban issued.
            We moderate this forum and if a simple polite warning is ignored then this is the next course of action.
            • digicon
              • 8261
              #156
              Originally posted by happy_highlander
              I am getting serious glitching and sometimes no broadcast at all on tm5402 hd channels in the evening (usually just films and sports but it is starting to spread to other hd) sd are fine. Strange thing though is I have exactly the same set up details (so to speak) in my solo clone and experience absolutely no issues at all, to the extent of testing the same channel in both boxes at the same time. So my conclusion is that closed source are likely to be effected much more than Linux. It would be handy if the lads could come with an updated add-on for tm.
              HH,
              I have a DrHD Grand triple here closed source but runs a very similar system to the 5402 and Blade and have not noticed anything at all difference between this and my Uno and my new Solo2 all are working as expected.
              Regards
              • mdt
                • 3034
                #157
                Originally posted by ohno
                ok since the first post went over your heads could we possibly have some constructive spoonfed infomation?
                "has anyone managed to run a card (over lan of course)with no glitch that took its last update in an original hd reciever thats had the new software on it? ie new epg etc within the last month.
                if the answer is no then doomed is the word your looking for and move on!
                my original hd reciever has been updated 3 weeks ago with software and had the card update 2 days after and all is running fine here. regards mdt
                • Manic01
                  • 5117
                  #158
                  Originally posted by satsmo
                  Despite what I posted on this thread only a few pages back Is this the End or The End is Nigh - Page 7 the next time I see mention of that specific UK provider from anyone there will be a one month ban issued.
                  Ban away mate if it makes you feel better.
                  First I| suggest that you trawl through all the posts on here with that providers name in them especially the openbox section and remove them all.
                  If you think its search engines that bring certain providers here and nothing to do with the actually content etc you must live in cuckoo land.
                  Anyway I will enjoy the ban and will go elsewhere.
                  • satsmo
                    • 6397
                    #159
                    My apologies for the delay in my response, as I was quite busy today.
                    Thank you for your suggestion of trawling through all threads and posts with the same providers name. I can do that quite adequately with a simple search and then edit each with a muti post moderation. Although as you have "helped" run so many forums I thought you would have known this.
                    Whereas my warning was to a V.I.P. member that should understand how spiders work, given a thread title based on keywords, again it looks like you either misunderstood this simple request or simply didn't understand it, but as you stated you helped "run" so many forums I thought this would be quite simple for you to understand.
                    I have also noted your recent posts on other threads whereby you negate the recent high ECMs on this particular provider based purely on your knowledge of the NDS encryption system. You have used your "status" here and across numerous forums as to appear knowledgeable about such matters. But to say you are far from knowledgeable in such topic is an understatement.
                    You simply cut and paste what at best is second hand information and then try to peddle it as fact. Your comments on the fact that the satellite scene has been ruined by the cable plug n play faction has some merit, but you and your friends on the commercial side have driven this, despite you continuously distancing yourself from them.
                    You have never understood the true meaning of community and also never understood the how and why the community works under the scene without the commercial BS.
                    With that I reserve the right to live in "cloud cuckoo land" and also to ban you for life for not only this post but many others.
                    Enjoy the ban and God help elsewhere.
                    • Shady
                      Shite Link King
                      • Dec 2010
                      • 6404
                      #160
                      is it wrong that i got turned on by all that?
                      • PremierD
                        TAMINATOR
                        • Jun 2009
                        • 13143
                        #161
                        Yes mate ... it is wrong ...
                        • cactikid
                          • 12017
                          #162
                          is that another cloud product thats new to me,only moving on from the vcr
                          • andy91
                            • Aug 2010
                            • 3583
                            #163
                            Not great to see a VIP member venting their anger like this but this also shows to new members that not everyone on here has a divine right to be rude.
                            Good on you Satsmo I know it can't be easy moderating a forum but I hope this serves a purpose in educating members whoever they are and how important they think they are that they can get away with snide comments like that.
                            Andy.
                            • the man
                              • 1660
                              #164
                              this could be the key then!
                              • leez
                                • Mar 2009
                                • 321
                                #165
                                well guys been watching this thread and its going nowhere . okay changes are going to happen. it was stated earlier on
                                but ive had no bother live events etc ..
                                i think alot is down to overloaded, paid servers and thats is what a shame ..
                                its illing the hobby anyway ..people who do this are just killing it ..
                                the end will be nigh ..and its all down to paid server greedy people.
                                dreambox 800 tech 500 ( ubuntu 10 .04)... 1 m dish v box 2 acuator ..
