Hi guys,
A noob question from a noob member..
I am seriously considering ditching cable and going to satellite but I have a few questions that I hope someone can help me with. Please bear with me! What I would like to do is get a dish and box that are capable of providing both UK and Euro channels. I understand that I will need either a motorised dish or a multi LNB on the one dish. So...
1) I've been given a 60cm standard dish with one quad LNB. I've been told that I may need a 80cm dish in order to pick up Euro channels better. Is this correct?
2) Motorised or multi LNB? I've heard from a few installers that motorised dishes can be a complete nightmare; so I suppose a multi LNB would make sense. Is it a simple matter of fitting two LNBs on the one dish? I would then need to purchase an additional quad LNB.
3) This is what is confusing me most. Eventually I would like to get two STBs, both twin tuners at some point. Initially I would get the one just to be sure it works ok etc. Anyway, would I need to run two cables from each LNB into each box? So, if I had two LNBs on the one dish (one pointing to e.g Astra and the other pointing to Eurobird), I would need a total of eight coax cables run? Or should it be four? This bit is totally confusing me!
4) This is much less important, but could I record something on a Euro channel whilst watching something on a UK channel with a multi LNB setup? Not a deal breaker but just something else Im curious to find out.
5) I've looked at a few potential STBs to purchase and they have this listed which I guess is significant. Can someone please explain briefly what this is?! multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported)
6) Finally, what are the two satellites I should point towards if going for a multi LNB setup? I think Atra 28/2 is one, not sure what the main Euro one is.
Thanks a lot for your input here. Again, apologies for all the noob questions. I've had a good look through the forums and whilst I have picked up quite a lot of useful info, it would be nice to get some specifics. Cheers!
