how do i put my lataitude and longitude in like
  • youngie1
    • Sep 2009
    • 184
    how do i put my lataitude and longitude in like... i am using vu solo box live in leamington spa thank you all lee
  • flyingpig
    • Aug 2009
    • 930
    Do a google search... It will tell you..... There is also a handy thing on UKCVs website - (i seem to recall)
    With either of them you put your postcode in and it will give you it.
    Lat - Long Finder: This page helps you find Latitude and Longitude
    Hope I have done the link right.
    • andy91
      • 3583
      Ive always used this put your full address in including house number, Andy. Satellite Finder / Dish Alignment Calculator with Google Maps | DishPointer.com
      • youngie1
        • Sep 2009
        • 184
        Latitude: 52.2666?
        Longitude: -1.5330? how do i enter it the box cheers lee
        • ramjet
          • 2995
          copy and paste from a solo2 tutorial below
          Setup Motorised Dish using USALS
          First get your longitude & latitude info from _http://www.satsig.net/maps/lat-long-finder.htm
          Enter your post code into satsig.net and you'll get the correct LON & LAT info for your location.
          Example if I enter the following UK postal code: SE1 6JZ into _http://www.satsig.net/maps/lat-long-finder.htm
          I get the following LON & LAT:
          Longitude: -0.1042?
          WEST
          Latitude: 51.4979?
          NORTH
          If your longitude is a negative number i.e. it has a "-" sign before the number then you have to subtract that number from 360.
          360 - 0.104 = 359.896
          So you'd enter 359.896 in your Longitude Settings.
          Press Menu
          Select Setup Press OK
          Select Service searching Press OK
          Select Tuner configuration Press OK
          Select Tuner A Press OK
          Configure Tuner for Motorised Dish using USALS.
          Use the < > buttons on remote to select Simple.
          Use the down button to select mode and use the < > buttons to set to Positioner.
          Configuration Mode: Simple
          Mode: Positioner
          Longitude: 359.896 (Make sure you enter your own Longitude settings here)
          WEST
          Latitude: 51.497 (Make sure you enter your own Latitude settings here)
          NORTH
          Press OK to save.
          Press Menu
          Select service searching Press OK
          Select Positioner Setup Press OK
          Select goto 0 Press RED Button
          Dish should now goto 1w.
          from that site the following is shown for leamington spa
          Latitude = 52.2852, Longitude = -1.5201
          Lat = 52 degrees, 17.1 minutes North
          Long = 1 degrees, 31.2 minutes West
          • andy91
            • 3583
            Try 052.266 and 001.533
            • ramjet
              • 2995
              dont you mean 358.477 for the longitude ?
              and 052.266 N for the latitude ?
              • youngie1
                • Sep 2009
                • 184
                what is the best sat to do first so they should all full in line cheers lee
                • ramjet
                  • 2995
                  if your dish and motor are all correctly installed then it doesnt matter which you use, although you are best to start with 1 west which is due south of you
                  if you install an up to date E2 list like the catseye one you wont have to scan anything in
                  check the VU forum here for more details on your solo
                  • youngie1
                    • Sep 2009
                    • 184
                    my dish just keeps turning and not stopping was working on 28 but not anymore doing my head in now cheers mate lee
                    • youngie1
                      • Sep 2009
                      • 184
                      ok mate i am stuck i am using a skybox f3 now as the vu solo is to hard for me..... local longitude 000.00E local latitude 00.0N what numbers do i enter in here mate cheers lee
                        just enter post code here Find latitude and longitude with Google Maps
                        • youngie1
                          • Sep 2009
                          • 184
                          I KNOW THAT MATE THANK YOU I JUST DONT NO HOW TO ENTER THEM INTO MY F3 SKYBOX Latitude: 52.2666?
                          Longitude: -1.5330?
                            no need to shout .
                            • cactikid
                              • 12017
                              i would be shouting if i had a sh1tebox also
