sure do that why I can see the ecm times etc nothing wrong with cams or lines connected to server ok its just blank screen on pay channels I have the vix installed
Are you using Oscam to clear? If not try CCcam I've seen this with Oscam where it clears but blank screen. The other thing you can try is an older or new Oscam if thats the Emu your using.
Reason: Highlight
no m8 I use mgcamd as I have nlines don't like using Nlines in ccam.conf as mgcamd is more stable , will try the openpli image later cheers alex
Reason: Highlight
You four members what is it that you plainly dont understand what gmb45 has posted about reading the rules, I have highlighted each term you are not allowed to discuss on this board simple as that.
Were commenting whether it works or not with specific images on a specific box, jeez.
The forum rules are there for every member to abide by if you don't want to abide by the Rules then you are free to discuss this anywhere else apart from on this Forum.
That one rule i quoted is pretty specific no discussion of any kind full stop.
