cloud ibox 2
  • pl1976
    • Feb 2010
    • 213
    #466
    Originally posted by kazaaman
    Here you go lads, i bought 10 of these Cloud Ibox 2 stb's, flashed VIX on to them, set them up with a 1tb external drive attached & used vix backup manager & popped that onto the next 9 after, every 1 worked absolutely perfect & never faltered whatsoever, really impressed right now with these.
    I then threw on RATS DW Channel updater & OnDemand Plgin and both were great too.
    This is a link to my VIX image that I flashed onto mine, works 100% every time.
    https://mega.co.nz/#!hxt2GIQR!LqrQDE...hn19PXzuyVSbNg
    Does this have tsmedia ?
    • bighun
      • Nov 2010
      • 151
      #467
      what build of vix is it
      • orientville
        • 66
        #468
        Managed to install tspanel and d/loaded tsmedia from there alas 1channel and icefilms r not working at present but there r plenty of other streams to play with
        • orientville
          • 66
          #469
          openvix version 3.0 build 600
          • alex123
            • 832
            #470
            hi lombard I used your pli backup works great thanks plenty on it only problem is am getting crashing on one channels and some other on TSmedia which has been updated but working fine on my duo so was thinking maybe lack of memory on ibox so deleted a few extra plugins but cant find the picon folder as going to put that on an usb stick any ideas . cheers alex
            • lombard
              • Aug 2008
              • 793
              #471
              usr/share/enigma2 , also note tsmedia is hit and miss, i updated to 4.6 and most of the movie links do not work, also i still have about 100mb free so have enough space
              • RuberDuck
                • 1724
                #472
                Because the service providers are actively blocking the servers that feed such plugins due to the piracy crackdown.
                you can read about it here
                http://www.xbmchub.com/forums/1channel-plugin/15520-primewire-blocked-uk-end-month.html
                • lombard
                  • Aug 2008
                  • 793
                  #473
                  there is a way to bypass via the sites though
                  • RuberDuck
                    • 1724
                    #474
                    yes i know there is.
                    • steviestring
                      • Sep 2013
                      • 17
                      #475
                      Can you say how to for the plugin? 1channel has stopped.
                      • mo.p
                        • 298
                        #476
                        try this
                        Openpli 4.0 Lombard Backup Ibox 2 12.11.13.rar
                        if it doesnt work, then probably something wrong with box , as i know image works 100%
                        i have been running this box with image openpli 4.0 for 2 days now no issues at all with epg, channel logos all on internal flash, i would say its better then the ibox 1 , doesnt heat up at all, slightly faster, and more memory 256mb flash / 512mb ram, no idea why they advertise 2gb flash / 4gb ram, for the price probably couldnt really expect that
                        only thing i dont like is the blurry info bar you get when first select channel, or gets quite alot if have picons to show on channel list
                        hi m8 thank very much for the image ive just added few thing more and i am trying to make a backup i useing usb for crossepg working fine but trying to make a backup on my usb but cant do it plzzz any help/info would be greatly appreciate
                        • lombard
                          • Aug 2008
                          • 793
                          #477
                          use backup 1 to 1 usb plugin its in plugins and make a backup to usb , you need to create a text file on the usb called backupstick.txt for it to work.
                          • tkm18
                            • Aug 2009
                            • 158
                            #478
                            Theres a fix been posted elsewhere, not sure if its on here yet, but its still a wee bit hit and miss the now, using a primewire proxy.
                            • northlad
                              • Apr 2010
                              #479
                              Anybody got a spare cloud ibox2 as theres a fella toysoft who is willing to make us an updatable vix image but he needs a box 1st to build it?
                              • RuberDuck
                                • 1724
                                #480
                                Look again, he closed your thread as it's not a Ferrari brand clone so he wont help you.
