Thought that m8. Could I take one from a mini solo or can you buy them local. Cheers mate
Sent from my GT-I9300 using Tapatalk
Just solder a small peice of wire from the centre pin of the connector to the solder point on the board. you could use something like the centre conductor out of a peice of coax or something similar
get a small bit of coax cable strip the brown outside of then the white inner that will leave you the copper solder it to the the middle wire of the satellite connector then solder it to the point on the main board where the wire should go
Hello I have had many problems with the seller from aliexpress susana lui Store called dvb shenzheb Electronics Factory. You do not buy the Cloud ibox2 in that store, they are scammers.
Hi, i done the fix soldered the resistor and been working full 1 day now before didn't last 30min-1hr, using latest vix 3.0 build , epg , picons saved in flash memory still have 90mb free, not had no issues and everything seems to work fine, although with same setup on vu solo , the solo does noticeably run much smoother and faster, channel hopping etc, downloading epgm can really notice difference
All of the 8 repairs i have done are still working 4 days later, but i have had boxes fail that are a month old so how long they last is another story.......
I agree the solo clone is a better box overall, that being said the biggest issue with cloud2 are the images, like the blurr on the epg. For me the openATV is the best of them.
you can always use small wire, the smaller it is the less OME it gives, i put 0,2 ome wire 5cm and it works very well.
Ps. tryed all images, ATV open gives me best picture and stabilty.
Hi, Can anyone recommend a supplier of this box that is sending them with the replacement fixed resistor ? I want to buy 3 of these for the family but don't want to have the hassle of having to fix resistors, I bought one of the first batch from Airsat and I have had no problems yet, I won't be buying any more from them because they don't take Paypal any longer. They also sent it with no card reader.
Cheers
