how to install a motorised dish
  • standarren
    • 857
    #31
    Originally posted by thered
    ok so when your dish spins round from say 28 to 13 how far from your wall is the dish getting closer to wall
    miles away from the wall
    • standarren
      • 857
      #32
      i've just reflashe the box as i deleted hotbird as soon as the box turns on its says moving to astra 19.2 then says bad signal
      • standarren
        • 857
        #33
        ok so can someone confirm this is my details of where i am
        Latitude: 52.4216?
        Longitude: -1.9137?
        • standarren
          • 857
          #34
          shall i put the ladders away for today
          • thered
            • Aug 2008
            • 4915
            #35
            your dish isnt lined up correctly then
            try and get the maximum signal strength by adjusting the dish on the pole l/r and u/d
            if you are unsure of where south is for thor you can use UK sky to set your dish i have and it worked fine
            point your dish to where your sky dish is pointing make sure it recieves the maximum signal you can get by nuging the dish to optimum signal strength and also make sure your pole is dead straight
            then go to your box and set your long/lat and then do a manual search for 19.2 the dish should go to it if its all lined up correctly if ok try the rest it should find them all
            if however say it finds some but thor is weak or not at all its one of a few things
            your dish is not level and its losing the arc as it swings round its not big enough or there is something in the way
            • standarren
              • 857
              #36
              is 19.2 the sky sat
              • dick b
                • Jun 2009
                • 2462
                #37
                no 28.2/5 is the sky sat
                • jpr
                  • Jun 2009
                  • 161
                  #38
                  I installed my first motorized dish using this guide and recieve all sats with perfect quality, Thank you.
                  • tetta73
                    • Oct 2010
                    Hello all...
                    I'm a satfan from South Brazil and i want to know where in London can i bought some stuff like Azbox Smart and a motorized dish (only the motor, as a matter of fact)...
                    My brother will go to London next week and i want to buy some stuff like this for me...
                    Ty very much...
                    Tetta73
                    • sleeker
                      • Feb 2011
                      excellent guide on installing a motorised dish will refer back to this for sure thanks
                      • Fredwinf
                        • May 2010
                        • 39
                        #41
                        forget that last post, just stopped something and answered my own question, ive been in and out all day trying to find sats!! bloody thing cud of just used usals! what a numpty
                        • punxxxter
                          • 184
                          #42
                          hi
                          is thor 1w thor 0.8?
                          • handyguy2002
                            • 95
                            #43
                            Thor @ 1'W
                            its tells you on first page mate
                            • punxxxter
                              • 184
                              #44
                              on the 1st page it says line up to thor @1w.
                              my question was is thor 1w, thor 0.8...
                              • punxxxter
                                • 184
                                #45
                                no matter now, i found the answer to my qestion on satellite dreambox stickys ,installing a motor and the answer is yes it is the same satellite.
