People in the NW England
  • socktug
    • Jun 2009
    • 38
    #31
    Do you also have an up to date channel list, and satellites.xml file on the box? If they aren't installed or the satellites.xml doesn't correspond to the channel list, then the motor won't move. See if someone has a full working backup image that they can upload for you to try...
    • ecowarm
      • 35
      #32
      Thanks Socktug, always happy to see another idea thrown my way.
      Don't think I have either, just got the standard images on it then have set everything else up through the box itself. Thought you started with a fresh image and built the rest up from scanning the transponders. Anyone able to help with this by passing a working image? Promise I won't reveal any embarrassing channel preferences in your listings (Channel 1: The Wedding Channel, Channel 2: Gay Dating, etc).
      extremely appreciated or PM me for email address if easier.
      Blackbox DM500 clone, Penta 88 Dish, Technomate motor and a massive headache getting it to play nice.
        Did you try your technomate again m8 to see if that turns the motor. If it doesn't turn it now and it was before then it's got to be the motor.
        • ecowarm
          • 35
          #34
          If it was mine that would already be ticked off. The Technomate came with the installer. It was tested as working after we failed to get the Dreambox to work, I thought I was missing a setting but not so sure now.
          • psats
            • 823
            #35
            dreambox 500 have lower power output than normal box,s i can move my 1.1 thats at end of the garden with a couple of box,s but no chance with the dream even with a higher watage power supply
            • ecowarm
              • 35
              #36
              I am only moving a light 85cm dish with a fairly short cable so it really should be able to handle it (hopefully).
              • ecowarm
                • 35
                #37
                Thanks for the help guys. Sat man came back and said the motor has crashed so reset it. He reckons the Dreamcast sent it a load of garbage so will try again with a manual setup rather than GotoXX first.
                • opsmonkey
                  • 5379
                  #38
                  .. no wonder its knackered..! fancy using an old crappy Sega games console to try to move your dish..
                  Good news mate....
                  it has to be manual setup.. D500S does not use GotoXX
                  • .: JaCkPoT :.
                    Retired Sat TV Addict
                    • 5611
                    #39
                    FPMSL! DreamCast..theyre older than me. Some say GotoXX work others say it doesnt on the 500s. Which is it? it dont work on mine.
                    ___________________
                    In the good old days, I had
                    DM800s HD
                    Openbox S10
                    TM500
                    DM500s
                    90cm FortecStar dish
                    Maxx 110cm Dish
                    Technomate 2300 Motors
                    • ecowarm
                      • 35
                      #40
                      At many points in the past couple of days I would have gladly exchanged it for a Dreamcast, best console ever, FACT. Anyway I accidentally tried GotoXX on mine when I got home and it worked. Connected it up to see where I was up too last and selected a Sky channel. It then moved itself from 0deg to 28.2deg and locked in no probs.
                      Checked the settings and it was on GotoXX with Sky scanned on the minidish previously to check it was alive. I have got a feeling that the missing link in the GotoXX situation is programing in the Sats and maybe scanning them before trying letting GotoXX try to do anything. Maybe it needs to know what it is looking for in more detail than the GotoXX software contains, maybe it is a bug.
                      Tonight or tomorrow I am going to stick the Captains Settings on a fresh PLI image and then try a controlled GotoXX experiment myself. Now I know that I can sort things with a biro and my dad's long ladders I feel much less stressed about knackering things.
                      • boothuk
                        • 251
                        #41
                        * MESSAGE DELETED *
                        • opsmonkey
                          • 5379
                          #42
                          id pole mount it so it sticks over the top of your roof
