Zgemma 2s OpenAtv 5.2 Backup Image with Improved $ky Skin
  • happy_highlander
    • 3535
    #211
    Should have went the extra pennies and and got a vu solo v2 or a solo2 honestly you wis not have been disappointed. Let me know how much better the h series are though
    • martin035
      • Apr 2014
      • 1308
      #212
      Aye, did look at a whole range of boxes but couldn't justify the expense of a vu or xtrend box.
      As to how much better the H series is, well quite simply it's a lot faster doing the following;
      Flash an image
      Boot time
      Crossepg save/load after download
      Pulling in the EPG info when access the main EPG
      Scrolling through the main EPG
      Scrolling through the fav menu
      Basically it a faster version of the 2s, the last 2 points been the reason why I wanted a new box as the lag was annoying.
      • randomry
        • Mar 2016
        • 11
        #213
        Great build as was the last one, i only have one issue, why are the picons so dull on this one? and is there an easy way to change them so they are nice and bright like in the previous image?
        • martin035
          • Apr 2014
          • 1308
          #214
          MK's Picons ie the nice and bright ones, have a huge memory footprint and a complete set would fill the zgemma's internal flash, on the older images only a select few were added, with the new set you get a complete icon set for all channels at a fraction of the size and it's the most current picon set.
          1. Download the picon.zip and unzip the folder
          https://www.dropbox.com/s/j60te4juawdg2sr/picon.zip?dl=0
          2. Weed through the picon folder and remove all 'none working' HD picons, Incorrect referenced picons ie Animalplnt as the correct one is Animalplanet etc, Vmedia picons and picons for any bouquets you don't use ie if you dont use the 'Adult channels' remove all the 'named adult picons'. This will reduce the size of the picon folder.
          3. FTP to zgemma's picon folder location /usr/share/enigma2/picon and delete all the files in that folder
          4. FTP over the picons in your already weed out picon folder to picon folder on the zgemma /usr/share/enigma2/picon
          5. reboot
          You could place the whole unweed picon folder on your USB drive and do it that way but you will get a performance hit when accessing your EPG/Fav/InfoBar so I don't recommend this.
          You could also, just go to the plugin menu and download another picon set but this is hit or miss to how updated the picons are.
          • randomry
            • Mar 2016
            • 11
            #215
            Wow thanks mate for such an indepth reply, I'm not complaining just being a fussy get , its fine although cos I like tinkering I might do as you suggested, thanks again
            • riley24
              • Feb 2013
              • 30
              #216
              Thank you Martin for the nice crisp image
              Could you let me know how to change the size of the box that appears when inputting a channel number
              • martin035
                • Apr 2014
                • 1308
                #217
                For the original Zgemma series ie s 2s h1 h2 using kiddac's skin then;
                1. FTP the following file from your zgemma to your PC desktop /usr/share/enigma2/slyk-1-hd/general.xml
                2. On your PC open general.xml with an xml editer and find the following;
                <!-- numberzap -->
                <screen name="NumberZap" position="108,593" size="240,81" flags="wfNoBorder">
                <ePixmap pixmap="mybackgrounds/numberzap.png" position="0,0" size="240,81" zPosition="-1" />
                <widget name="number" position="15,5" size="210,38" backgroundColor="skydarkblue" transparent="1" font="skymed;25" borderWidth="0" valign="center" halign="center" foregroundColor="white" zPosition="1" />
                <widget name="servicename" position="15,45" size="210,38" backgroundColor="skydarkblue" transparent="1" font="skymed;25" borderWidth="0" valign="center" halign="center" foregroundColor="skyblue" zPosition="1" />
                </screen>
                3. Change the Sizes and Positions to suit and save the general.xml file
                4. FTP your new general.xml file from your PC to your Zgemma /usr/share/enigma2/slyk-1-hd/
                5. Reboot
                • gersweeney
                  • Jan 2014
                  • 12
                  #218
                  Hi Martin
                  I am having problems with my Zgemma Star 2s with a image on it Zgemma 2s Vix 4 1.001 Sucmnsee on it . I am trying to install your image on it but what is after happening i put the usb stick into the rear of the box but was unable to install the image now its stuck in reboot mode with a red led light on i cant get it to do anything now any help would be appreciate any help on this
                  Ger
                  • martin035
                    • Apr 2014
                    • 1308
                    #219
                    Originally posted by gersweeney
                    Hi Martin
                    Ger
                    Ok, redownload the image from post#1 unzip and place the 'zgemma' folder on your USB drive, then it to the rear USB port. Power up the box, on the front it will say 'BOOT' then 'USB' press the front standby button it should then say 'FLSH'
                    • gersweeney
                      • Jan 2014
                      • 12
                      #220
                      Hi Martin
                      That worked perfect thanks i was using the wrong USB drive one more thing i ran Autobouquets for the ROI channels and it did not work the Irish channels are all over the place is there a update to rectify this please
                      • randomry
                        • Mar 2016
                        • 11
                        #221
                        My mate tryna install this everything fine until he tries to format hdd and gets this 13072194_10156871306980078_1242385391_o.jpg
                        • martin035
                          • Apr 2014
                          • 1308
                          #222
                          Hi Martin
                          You don't need an update to fix, I've set up the image to do this so that the Irish channels people want to use in the UK are added to the main bouquets ie Setanta HD is added to sports. Anyway to fix it do the following on the remote;
                          Menu-setup-service searching-autobouquetsmaker-configure
                          Include 'not indexed' channels change to 'No'
                          Setup your ROI and $ky(uk) regions and scan.
                          • martin035
                            • Apr 2014
                            • 1308
                            #223
                            My mate tryna install this everything fine until he tries to format hdd and gets this [ATTACH=CONFIG]370847[/ATTACH]
                            Try formatting the USB drive he used to install the image with, if it completes the format sequence then it's a problem with the HDD. Try formatting the HDD in a PC first then get the Zgemma to initialise it.
                            • randomry
                              • Mar 2016
                              • 11
                              #224
                              Done as you suggested mate, it finds them fine but it just won't mount them, he usually uses a 320gb ,that wouldn't. And just tried stick used to flash after formatting and does the same. Weird ain't it
                              • martin035
                                • Apr 2014
                                • 1308
                                #225
                                Slightly confused, what do you mean 'it just just won't mount them' what are you trying to do with the drives.
