For some reason since I installed this image I cannot get film 4, more 4 and E4. Anyone else experiencing this?
Zgemma 2s OpenAtv 5.2 Backup Image with Improved $ky Skin
You could try a software update, follow the instructions inImportant Notice in post#1 and see if that makes a difference.Comment
Hi I had a new zgemma star 2s and I installed a new image USING THE USB METHOD. Now I want again to install another image using the same method but is not succesfull. I try factory restore but the same image comes buck, could you please help by telling me how to unistall the old image please, thanks tassosComment
Hi sorry for the delay is VIX that I put by mistake and I understand is for MaxiDigital 1000. I want to find ******** but I can,t so I would like to change the image, is any tool that can reflash as the usb method is not working any more, your help will be appreciated, thanksLast edited by Johnner; 2 December, 2016, 21:04.Comment
Go to this website and download an original Openatv image
Download the zip file and on your PC, format your USB stick drive to FAT32, make a folder on the USB drive called 'imagebackups' and transfer the downloaded zip file to that folder.
Then place the USB stick drive in your Zgemma' rear USB and switch it on
Then on the remote;
menu
setup
vix
image manager
blue to restore
This will give you a default Openatv image, you can then either configure it manually or install someone backup image ie the one at post#1 of this threadLast edited by martin035; 2 December, 2016, 21:50.Comment
