Zgemma H Series (H.s H.2s) Openatv5.3 Backup Image
might be better l dont know m8 best install the newest , l use on h1h and h2h and works fine m8 , cant bet a nowtv box thoany information provided is for educational/experimental purposes only.Comment
I use plex on all my recievers (and nowtv/firestick) and no offence smirnoff but the gigablue quad+and the xtrend et8000 both run plex better than nowtv
there are no 5.1aac playback issues which effect the firestick version. @martin if you want to use the H series to stream from a remote plex server I'd suggest you set it to trandcode for movies but will need to change it to stream or direct play for music
Minor Update 10/05
Minor Update: Due to bugs with the Sky Q skin I have changed the default skin to the Kiddac's Orginal and best Sky HD box skin, also added his latest Virgin media look a like skin for any cable user who fancy trying this out.
- Slyk HD 3.008 Skin added as Default skin
- VSkin HD 1.003 Skin Added for Cable users
Sky Q is still on the image and will be updated once chabs releases a new version.
Vskin pictures
EPG.jpgInfo.jpgMenu.jpgComment
Minor Update 22/05
Minor Update: Chabs has released V1.3 of his SkyQ skin fixing the majority of problems/bugs, unfortunately the Media Player plugin still crashes with this skin, either use another Media player ie Plex or another Skin.
- SkyQ Sikin updated to V1.3 and added as Default skin
- VSkin HD Skin updated 1.007
I'm thinking about signing up for an IPTV service that is compatible with my h2s.
I was wondering if there are any plugins or the like that can enable me to add my IPTV channels to a bouquet so i can access them from the EPG? And even retrieve what's on etc?
As integrated as possible.
Thanks.
IPTV List updaterI'm thinking about signing up for an IPTV service that is compatible with my h2s.
Thanks.
If using autobouquetsmaker ensure you set 'Keep all non-ABM bouquets' to 'Yes' in the ABM configue menu, else you'll lose you lists on an ABM scanComment
Yes, sounds like your epg.dat file is corrupt, do the following to fix
1. FTP to your Zgemma's Hdd /media/hdd and delete the epg.dat file
2. Menu-setup-service searching- ABM-Start Scan
3. Menu-Setup-EPG-load/save – save EPG
4. Press EPG and see if your EPG is populated then reboot and see if it's still been populatedComment
Castaway needs URL live resolver to work you'll most probably find that kodi direct hasn't be updated, how to update URL live resolver on kodi direct I don't know????Comment
Ill have a fiddle around, castaway would be an ideal add on if I can get it working!
Thanks for your help mate, really appreciated!
If you getting it working let us know pse, I've got castaway on my Kodi machine and with what's happened to the BT channels and maybe the future, this addon could stop my Zgemma become a future door stop.Comment
1. Go to menu-plugins then press red to remove installed plugins find 'autobouquetmaker' and remove old version
2. Go to menu-plugins then press green to install plugins find autoboubouquetsmaker' and install latest version
3. Go to autoboubouquetsmaker in setting and select 'delete bouquets'
4. Go to autoboubouquetsmaker in setting and select 'start scan'
this will remove the none working BT HD channels
Edit: Not required anymore ABM have updated there github to 2.1 which included an update feature;
Menu-service searching-ABM-Update Config files
Menu-serive searching-ABM-start scanLast edited by martin035; 23 August, 2016, 16:42.Comment
