Zgemma H Series (H.s H.2s) Openatv5.3 Backup Image
  • damiensk
    • Apr 2010
    • 201
    #106
    Hi Matrin035, do you know why ss1-5 roi have now gone from the sports section, along with eir sports? did a ab scan tonight, and they have gone.
    can still find them under the all section ok.
    thanks for any help
    • damiensk
      • Apr 2010
      • 201
      #107
      double post
      • martin035
        • Apr 2014
        • 1308
        #108
        thanks for any help
        Yes, a gremlin in the software, that causes problems from time to time, this normally fixes it;
        1. Menu-setup-service searching-ABM-update config files
        2. Menu-setup-service searching-ABM-configure and include 'not indexed' channels to 'No' press 'Green'
        3. Menu-setup-service searching-ABM-configure and include 'not indexed' channels to 'Yes' press 'Green'
        4. Start scan
        hopefully you should get those channels back
        • hfxlad
          • Feb 2014
          • 91
          #109
          hello great image thanks the epg is not very good on the cable side is there one to download in plugins? it does build up sometimes on some
          channels but hit and miss thanks.
          • damiensk
            • Apr 2010
            • 201
            #110
            [QUOTE=martin035;2867319]Yes, a gremlin in the software, that causes problems from time to time, this normally fixes it;
            4. Start scan
            Hi Martin035,
            yeah, channels are back.
            didnt work on the first go,
            so did a re-start after line 2 Menu-setup-service searching-ABM-configure and include 'not indexed' channels to 'No' press 'Green'
            and did line 3 as per, and after the scan, hey presto as they say.
            thanks for your help
            • martin035
              • Apr 2014
              • 1308
              #111
              Yes, the installed 'Crossepg' plugin only works for the satellite EPG, for cable EPG you need the Epgrefresh plugin, download from the plugins menu.
              • Kirky84
                • Sep 2016
                Hi mate regarding the ss roi and eir is there a way to stop them disappearing once you have them. Lost again after a few days. Thanks
                • martin035
                  • Apr 2014
                  • 1308
                  #113
                  It's an issue with Autobouquetsmaker' scripting, which is way beyond my level, all I can advice is doing what I stated in post#108 and confirmed working by damiensk at post#110, might take a couple of scans , then once you got those channels back is to turn Autobouquetsmaker's daily auto scan off and only do manual scans when needed.
                  • martin035
                    • Apr 2014
                    • 1308
                    #114
                    A few new Channels/Rebrands added this week, here's the picons for the new channels, just FTP to /usr/share/enigma2/picon will added at next update.
                    • pupuqiop
                      • Sep 2015
                      • 41
                      #115
                      Great skin and epg, thanks a lot for all your hard work Martin.
                      • Hadron
                        • 2102
                        #116
                        Just upgraded from an H2 to an H.2H. Thanks for your backup image martin. Working on both Sat & cable.
                        Had 2 or 3 crashes causing the box to reboot. Happens while scrolling through the EPG & then selecting a channel. Not sure why. Didn't have time to read the crash report before the box rebooted. Might try a different skin (using default $ly Q skin at moment).
                        • martin035
                          • Apr 2014
                          • 1308
                          #117
                          Cheers Hadron for the info, was it just a matter of changing/configuring tuner B and ABM for cable and installing a cable EPG.
                          Not to sure about the crashes but I'm sure when your bored you'll have a look at the crash logs, might be a conflict between the sky Q skin and the movie organiser plugin as I sometimes get the odd crash after watching a recorded program then changing channels.
                          Also try MK picons, they do look good with the sky Q skin.
                          Edit: Confirmed, there was a bug with SkyQ V1.5 skin causing the box to crash, V1.6 fixes this bug, I've taken down the backup image and will update the Skin to V1.6 and add the latest picons, hopefully tomorrow.
                          • martin035
                            • Apr 2014
                            • 1308
                            #118
                            Software Update 31st Oct
                            Software Update: Chabs' SkyQ skin updated to V1.6 to Fix movie player to channel selection crash bug, autostandby added @00:50, Tuner driver updated 'disequ to yes' not required anymore, picons updated including sky Musicals
                            • SkyQ Skin updated to V1.6 (Toppicks Edition)
                            • Autostanby timer added
                            • Picons updated
                            • Tuner drivers updated
                            Sky Musical Picon added below for those not wanting to reflash their Zgemma
                            • Hadron
                              • 2102
                              #119
                              Originally posted by martin035
                              Cheers Hadron for the info, was it just a matter of changing/configuring tuner B and ABM for cable and installing a cable EPG...
                              First thing I did was configure ABM to add provider prefix to bouquet. It makes it easier to see if you are on the sat or cable tuner. In the ABM providers, I enabled Virgin UK & selected my area. Set up the bouquets.
                              Enabled tuner B for DVB-C (although I'm not sure it it was already enabled). Put in my network ID. Service scan type = Provider & chose Virgin Media (6952) as my provider. I then did a service search scan on tuner B only (as the sat side of things was already set up). Took around 25 minutes I think.
                              Finaly, I did an ABM scan to put the channels in their Favourite folders.
                              I havent installed EPG_refresh yet, as for some reason, I got a 7 day EPG on the cable channels when I first set the box up. It's gone now though.
                                #120
                                It should not take 25 mins for ABM to do a cable scan for doing both Sat (UK+Ire) and cable on a H series should take around 2-3 minutes tops, the cable EPG will load if you set the EPG - Settings - Enable Virgin EPG to 'On' when you goto any Cable channel and remain on that channel for around a minute the EPG will populate.
