Zgemma H Series (H.s H.2s) Openatv5.3 Backup Image
  • maxalman
    • May 2016
    #31
    Hi, I would like to try this build on my H2s I have Wooshbuild on my box at the mo, do I just flash this build over the top of Wooshbuild?
    • martin035
      • Apr 2014
      • 1308
      #32
      Yes, backup any important cfg files first then flash the image it will over write woosh's build, then restore your important cfg files and setup the Zgemma following the instructions in post #1
      • maxalman
        • May 2016
        #33
        Thank you for the advise, just flashed and all working good thanks.
        • martin035
          • Apr 2014
          • 1308
          #34
          Minor Update 29 Jun
          Minor Update: New Channel picons
          • Picons added for the following new channels; viva, MTV 90s, Box hits, Box upfront, Ginxsportstv, CNN HD, Hill Song & Eman Channel
          • martin035
            • Apr 2014
            • 1308
            #35
            Minor Update 9 July
            • Picons added for the following new channels; $ky Cinema Rebrand and eir sports Rebrand
            • martin035
              • Apr 2014
              • 1308
              #36
              Sky The Open Picon
              I'm not going to rebuild a new image for 1 Permanent and 2 temp picons, so for those of you wanting a Sky The Open, Sky Star Trek and Pop Max Picons
              FTP the attached to /usr/share/enigma2/picon
              • satsmo
                • 6397
                #37
                Martin I speak to the ladies and gents at Openatv on regular basis, if you are going to release V5.4 you better let them know
                Thanks for assisting with your backup on the forum.
                • martin035
                  • Apr 2014
                  • 1308
                  #38
                  Minor Update 28 July
                  Minor Update: New Channel picons & Olympic Bouquet added
                  • Picons added; from post#36, Harrypotter & Olympics channels
                  • Olympic HD & SD channels 1-8 added to Sports Bouquet
                  • martin035
                    • Apr 2014
                    • 1308
                    #39
                    Sky Spies Picon
                    For those of you wanting the $ky Spies picon;
                    • divyesh
                      • Mar 2010
                      • 16
                      #40
                      Hi this image work with h2h box?
                        #41
                        Yes it will but you will need to manually configure the second tuner on the H.2H
                        • martin035
                          • Apr 2014
                          • 1308
                          #42
                          AutoBouquetsMaker names the BBC Olympic HD channels differently to SNP Picon names of the relevant channels, if you wish to have picons for these channels just unzip the attached and FTP to /usr/share/enigma2/picon
                          Edit:Latest Backup Image has be updated to reflect this change
                          • martin035
                            • Apr 2014
                            • 1308
                            #43
                            Minor Update 5 Aug
                            Minor Update: As $ky Sports 5 ROI have the rights to broadcast the majority of 3 o'clock kick offs in Ireland instead of eir sports, I've added a custom bouquet with &ky Sports 5 ROI, $ky Sports 5 UK will not be showing any 3 o'clock kick offs. Also added missing/incorrectly named picons.
                            • Custom Bouquet 'Sports ROI' added with $ky Sports 5 ROI
                            • BBC Olympic HD 1-8, &ky Spies and xxxReal wives picons added
                            • damiensk
                              • Apr 2010
                              • 201
                              #44
                              Hi Martin035,
                              would i be able to delete the abm that i have on my box now and d/l the abm in the plugins, so that it gives me ss5 roi custom bouquet
                              would just save me a re-flash and going through a set up again.
                              thanks for all the hard work you put in for keeping these boxes upto date.
                              • holmesju
                                • Apr 2013
                                #45
                                Fantastic image mate runs like a dream on H.S, takes all the hassle out of setting up your own box. Keep up the good work
