Best Twin Box (2016) with Satellite And Cable and Recorder
  • clarkenuttal
    • Mar 2010
    • 47
    Guys sorry for a noob question but I've been out of touch with technology for some time.
    I am currently using Kryptview A780 for cable and Technomate 5402 HD for Satellite. I am now thinking to upgrade them and ideally looking for a box with following features:
    1) Box that can combine Cable And Satellite so I don't have to use 2 separate boxes (If such a box available)
    2) Box with HD features
    3) Box that supports record and playback for example box that can record one feed and play another or may be record more than one channel at a time. ( I can add HDD)
    4) Box that doesn't freezes much and has vs support.
    5) Budget is up to ?300-?350
    I really appreciate your help
  • DOUGALMCD
    • May 2011
    • 3229
    Try looking at vu duo 2 with twin sat and twin cable tuners [pluggable not fixed] excellent support for vu that will get you started. Have a good read up on E2 boxes as well.
    • martin035
      • Apr 2014
      • 1308
      1. Lots of Enigma2 boxes are combos ie have 1x satellite tuner and 1x cable tuner
      2. All modern Enigma2 boxes are HD capable, but not many HD channels left on satellite but loads on cable.
      3. Combo boxes do this quite easily, even better if you get a triple tuner box
      4. The budget you've stated rules out lower end Zgemma boxes which can stutter going thru the menus, if your on about freezing/glitching programs then this isn't down to the box
      5. For that price I would look at a Gigablue HD Ultra UE Triple tuner 1x satellite 2x cable with the ability of adding an internal hard drive
      http://www.world-of-satellite.co.uk/satellite-and-terrestrial/digital-receivers/gigablue/Gigablue-HD-Ultra-UE-Combo-1x-dvb-s-s2-2x-hybrid-dvb-c-t-t2
      • clarkenuttal
        • Mar 2010
        • 47
        What is the advantage of having 2 x Cable and 2 x Satellite Tuner over 1 x Cable and 1 x Satellite Tuner? Are all the above boxes capable of programing and handling different cams?
        • martin035
          • Apr 2014
          • 1308
          To watch one channel & record another you need a tuner for each, so if you have a 2x cable you can record/watch/stream 2x HD programs on cable, where as if you only had 1x sat 1x cable tuners you could be limited to 1x HD channel and 1x SD channel.
          Yes, but please remember cam talk is against forum rules
          • clarkenuttal
            • Mar 2010
            • 47
            Thanks Martin so ideally I should be looking at atleast Triple Tuner or more to be able to watch and record programs simultaneously? Also does it matter if recording is PVR or DVR or they both the same?
            • fevgatos
              • 14
              Hi all, personally i have VU+duo2 Twin dvb-s and dvb-c single,top box top quality ,and DM 800SE Genuine, no prefer clone boxis ,
              second box i would buy Miraclebox Premium ULTRA,this days no worth to buy any more satellite boxis ,c/s is going to end ,so what is the point buying this is my opinion ,
              regards Nick
              • martin035
                • Apr 2014
                • 1308
                I personally would get a triple tuner ie 2x cable 1x sat due to the reasons fevgatos says, if sat does die then atleast you will have dual cable tuners to record&watch. As to the pvr/dvr you can setup an enigma2 box to record to either its internal hard drive or external USB giving you portability if required.
                • clarkenuttal
                  • Mar 2010
                  • 47
                  Sorry guys I know its been a while this thread has been running. I wanted to know few more things if someone can help. Is there any Quad Tuner boxes available incase? Based on earlier comments my understanding of Quad Tuner is that It would allow me to watch either Cable or Satellite and record 2 channels at the same time (1 Cable, 1 Satellite)
                  • happy_highlander
                    • 3535
                    Yep plenty quad tuners. Gigablue quad plus, extend et10000 and vu duo 2 to name a few.
                    Sent from my SM-G935F using Tapatalk
                    • clarkenuttal
                      • Mar 2010
                      • 47
                      Vu+ Duo2 description says it is a twin tuner (NOT QUAD). But it also says record upto 16 channels simultaneously? Need a receiver that can play Cable and Satellite and record Channels (ideally upto 3 or more) while watching others (If it is a possiblity)
                      • happy_highlander
                        • 3535
                        Two plug and play twin tuner slots = 4
                        • clarkenuttal
                          • Mar 2010
                          • 47
                          How many tuners do i need to watch (either satellite or cable) and record say 2-3 more channels while I am watching something else?
                          • happy_highlander
                            • 3535
                            Each twin tuner has 2 feeds so you have 2 cable and 2 sat meaning you can record 3 channels and watch a forth or 4 sat, 4 cable whatever configuration you decide to buy
                            • clarkenuttal
                              • Mar 2010
                              • 47
                              So in order to watch one channel and record 3 more I will have to buy Vu+ Duo2 and add another twin tuner to it or standard out of the box will play one channel and record 3 more?
