installing motorised system
  • yamar1
    • 970
    #106
    Originally posted by melloned
    I've connected the dreabox to an ethernet cable from my router and powered up Mate , but stuck from where to go from there ! . I don't know if there's even an image on it ! .
    If i go " file mode " i can only open , plug-ins (blue button) , then select dream data and there are no services available. If i select "info" , in the main menu , nothing available in stream info ,nor much else wherever i look i'm lost ! . Think i'd best go for some pub therapy
    good idea few beers!
    without knowing which image is on your box, i cant say much, there should be a downloads or addons section. you relay need nabilo darkstar on then i could guide you through it as im quite familiar with that one.
    the image on your box may be corrupt now with the dreamup problems you had earlyer. have you tried the latest version of dreamup, works on vista as well as xp.
    here it is.
    Faster than Faster
    • melloned
      • 1215
      #107
      here it is.
      Digital Kaos - Downloads - DreamUP V1.3.3.5
      Hi Mate ( you're also are like a dog with a bone! ) , i'm already using the dreamup version above , it connects instantly , but whatever image i try to flash , flags up "aborted by user , exiting " about 15 seconds after i start the flash , i can get no further ! .
      I'm looking at asking the supplier to replace the box , but don't want to do that if there's nothing wrong with this one and i end up wasting ,his , your and my time !
      Just one question ? , when you unzip the nabilo image file and click on it's unzipped folder , do you get the winzip file logo inside it ?
      as that's what i get and am trying to flash to the dreambox .
      • firestorm
        • 1550
        #108
        the probable reason you get a winzip file when you extract it is that you have associated that type of image with winzip on your pc.So i don't think that's your problem
        What i would try is if you can find a old pc with a serial port (rs232) socket on the back i use one with win98 on it and try to flash it that way using dreamup
        • LiliG
          • 12
          #109
          I have a Dreambox 500s and a motorised satellite dish, can I change the satelites only through the Dreambox remote contorle?
          • yamar1
            • 970
            #110
            Just one question ? , when you unzip the nabilo image file and click on it's unzipped folder , do you get the winzip file logo inside it ?as that's what i get and am trying to flash to the dreambox .
            not wasting anybodys time, this is the fun bit!, once its set up theres nowt to do!,,,i get just an unzipped file (a white file it looks like),you can flash other ways via the earthnet but iv never done it that way, there is guides on here. just one thing iv never had a problem with rs232 dreamup and iv messed around with a few have you not got another box kicking around you could try to flash to see if your box is kaput? your to far away from me or i would have done it for you.
            flashing via telnet;
            Faster than Faster
            • melloned
              • 1215
              #111
              Tried it Mate , same result exactly , flash fails after about 15-20 seconds "aborted by user displays " .
              Thanks for trying !
              • melloned
                • 1215
                #112
                http://www.digital-kaos.co.uk/forums...ia-telnet-760/
                5 cable recievers Mate , all flash no prob ????
                • firestorm
                  • 1550
                  #113
                  it sound like your boot loader is cream cracked it may be a j tag to get it going so it would go back to the suppler if it was me
                  which image are trying to load?
                  It is a enigma1 image nabilosat is very good
                  • yamar1
                    • 970
                    #114
                    od
                    Agreed Firestorm, if you have flashed 5 cable boxes and it was ok i think you need to send it back ed, if its ok im sure they will tell you so.
                    Faster than Faster
                    • melloned
                      • 1215
                      #115
                      I'm arranging to return the dreambox to the supplier who says he'll replace it no trouble , but doesn't think thats were the problem lies , thanks for all your help Mates , i very much appreciate your time and trouble . I'll keep you posted when i get my replacement / resolution .
                      • yamar1
                        • 970
                        #116
                        Tbh, most are ok but you will find out when you return it, best of luck and giz a shout when you get it back, we will get you going!
                        Faster than Faster
                        • melloned
                          • 1215
                          #117
                          Hi everyone , just a note to say i've not topped myself or given up on the sat set-up .
                          In fact , i now have nabilosat image on , a decent channel list loaded and yesterday , after 2-3hrs tinkering with both latitude and longditude settings , i actually got a signal lock at approx 1 degree west (snr 85% agc 95%) and can watch bbc world news ! . Problem i've got now is , beyond 19.2 east , i cant pick anything up ( hotbird 13 east and 19.2 east , lock and view ) , nor can i pick anything up driving the dish west .
                          Anyone guide me as to what might need looking at ? , or can anyone recommend an installer in the widnes , cheshire area
                          who won't rip me off and can fine tune it for me ?
                          Thanks all .
                          • yamar1
                            • 970
                            #118
                            Thanks all .
                            wow, your almost there, great when you get the picture init?, did they change the box?. my money is on the pole not plumb, also the pole motor and dish must be in a perfectly straight line with each other. have another mess about and get the strongest sig in bbc world 1w with left and right movement on the dish, then ajust the lat on the dish (NOT THE MOTOR).
                            by the way well done.
                            Faster than Faster
                            • melloned
                              • 1215
                              #119
                              Hi again Mate , what you've just said has hit the nail on the head ! , the pole's totally 100% and the dreambox was Ok after all, (just me useless !) , but i altered the longditude from the original 54 degrees to 38 degrees , then adjusted the dish bracket to get a signal as i couldn't alter the dish bracket far enough up , to get a signal .
                              I now realise this was stupid and won't give me the correct arc when sat searching , but at least it's proven it all works !
                              So on my next spare time slot , i'll reset the motor to it's original 54 degrees and if i have to rebulid / modify the dish bracket to give me what i want , i'll do so.
                              The one slight prob is it lives 2mtrs above my bungalow , so down she comes again , Ta for the encouragement mate!
                              • yamar1
                                • 970
                                #120
                                anytime,, do you have it hooked up to the router for the next step?
                                Faster than Faster
