liveonsat.com is great for the footy listings tells you what sat/channel its on and where the channel is.
also just messing about here with the epg on darkstar 2. when you are on a channel press ok,info then multi epg or channel epg, seems to work with the chanel your on . hope that helps.
! keep you posted , and pestered
, ive now re flashed, added the channel list via dreambox edit, but now most of them jus says not found....so now i still need to edit the motor position for each sat, in order o get a signal....but cant seem to find 28.2e
