Required Dish Size Guide
  • Superman
    • 520
    #16
    I would go for a Dream or TM500/600 over anything else mate, there quite heave not to bad, id say 6/7KG.
    • Superman
      • 520
      #17
      There is around a 30? price difference in these models, you could always go for the HD model.
      • pomster
        • Mar 2009
        • 119
        #18
        Which dish which box?
        Hi people, i'm looking at getting on the satelitte bandwagon but i am new to this an have a lot of questions can you techno peeps help pls? First up from what i can understand a dream 800 hd sounds a good way 2 go with a 1m motor dish, i seen a tut for how 2 set up an azbox (v helpfull by the way) is a dr box simler 2 set up? Also how much would that set up cost me an are you forever updating or does the cs do that for you? Any advice would be much apprieciated, also i went to aldi an they only had 2 dish sizes 35cm an 45cm, would these be any good? From this site i sorted my wii out an my ex7000 which is about to become a doorstop so i'm ready for a real challenge!
        • red7
          • Feb 2010
          • 5
          #19
          how can i receive nilesat ?
          • satsid
            • Aug 2009
            • 815
            #20
            If in uk,this will change on footprint as to what part of the uk your in.The more north you are,so bigger the dish your need.South coast nearest to France you might get verts on Meter dish.Up north you need ish a 1.8 meter dish(verts).Hor signels might come in @ night time on a 1.8 meter dish(wether pending)So for clear viewing i would say 2.4 to a 3 meter dish for soild viewing all the time.
            • DEMONACER
              • Jun 2009
              • 122
              #21
              53' EAST
              Read up about receiving 53'east but I cannot for the life of me hit it.It supposed to be available with a 80cm dish except 12000 to 12750 bands those need a 1.2 mtr.I have a 1mtr motorised from 3'east to 45'east due to the way house faces and planning permission until I relocate it to bottom of garden in summer then it will be full east to west so at the moment i am content with the east birds.Does anyone have any suggestions for this please.
              • LiliG
                • 12
                #22
                To conclude, buy 120cm
                • adey1979
                  • 18
                  #23
                  Hi Guys
                  Im new to the world of sat i just got myself a
                  AZBOX HD PREMIUM
                  But not sure on what size Dish to get my main interest is the Premier league
                  if anyone can advise that would be great
                  oh and im in wolverhampton
                  • Golfman
                    • Jun 2009
                    #24
                    Required dish size fixed setup Astra 1, 2 and 3
                    Hello folks,
                    I am currently on the cable and thinking of switching over to satellite. I have quite some experience with satellite since I lived in the Netherlands before and always had a motorised setup there. I roughly sorted out the STB's so that is fine. For the new dish setup I want to be able to receive the Astra 1, 2 and 3 on a fixed dish. I had a look at the footprint page and since I live in Essex a 90 cm dish would do, but that is with 1 LNB only i asume, or is there enough margin to make that a multifeed setup as well? I am also not sure if I should go for a Triax (always had that, good quality) or have a Visio Bisat solution this time.
                    Any advise on this dish "problem" would be more then welcome.
                    Thanks in advance.
                    Golfman
                    • tattubato
                      • May 2010
                      • 8
                      #25
                      My 2 cents,
                      Go for a 1 metre dish if attaching to your house any bigger than this you will need planning permission or if on the front of your property where it can be seen from the road or if someone complains.
                      I have a 1 metre dish motorised on a scaffold pole on the back of my house but the dish is below the roof line so some what protected and the extra 10cm will improve the signal a bit.
                      If you want a bigger dish the prices start to get silly but better sited on the ground.
                      • satsid
                        • Aug 2009
                        • 815
                        #26
                        Originally posted by adey1979
                        Hi Guys
                        AZBOX HD PREMIUM
                        with azbox keep an eye out for feeds posted,if thay are posted from 8 west your need a inclined setup.
                        • supercatic4
                          • Feb 2010
                          • 11
                          #27
                          Have I read the table right. I am based in north west England and want to get Hotbird 13E. The table says 60cm. Will my old sky mini dish work?
                          • sepistar
                            • Jul 2010
                            • 2146
                            #28
                            Here is a very usefull site:SatLex Digital :: News,there are a lot of info about sat antennas.
                            Have fun.
                            • Hob
                              • 240
                              #29
                              Just a side note for planning regs in England on dishes above 1 metre (if you have a curtain twitcher of a neighbour).
                              Houses and buildings up to 15 metres high
                              Unless your house (or the building in which you live) is in a designated area, you do not need to apply for planning permission to install an antenna on your property, as long as:
                              • there will be no more than two antennas on the property overall. (These may be on the front or back of the building, on the roof, attached to the chimney, or in the garden);
                              • if you are installing a single antenna, it is not more than 100 centimetres in any linear dimension (not including any projecting feed element, reinforcing rim, mounting and brackets);
                              • if you are installing two antennas, one is not more than 100 centimetres in any linear dimension, and the other is not more than 60 centimetres in any linear dimension (not including any projecting feed element, reinforcing rim, mounting and brackets);
                              • the cubic capacity of each individual antenna is not more than 35 litres;
                              • an antenna fitted onto a chimney stack is not more than 60 centimetres in any linear dimension; and
                              • an antenna mounted on the roof only sticks out above the roof when there is a chimney-stack. In this case, the antenna should not stick out more than 60 centimetres above the highest part of the roof, or above the highest part of the chimney stack, whichever is lower.
                              Houses and buildings up to 15m high in designated areas
                              If your house (or the building in which you live) is in a designated area, you do not need to apply for planning permission to install an antenna on your property, as long as:
                              • there will be no more than two antennas on the property overall;
                              • if you are installing a single antenna, it is not be more than 100 centimetres in any linear dimension (not including any projecting feed element, reinforcing rim, mounting and brackets);
                              • an antenna mounted on the roof only sticks out above the roof when there is a chimney-stack. In this case, the antenna should not stick out more than 60 centimetres above the highest part of the roof, or above the highest part of the chimney stack, whichever is lower; and
                              • an antenna is not installed on a chimney, wall, or a roof slope which faces onto, and is visible from, a road or a Broads waterway. (If you are not sure, get advice from the local planning authority.)
                              Buildings 15 metres high or more
                              Unless your building is in a designated area, you do not need to apply for planning permission to install a dish or other antenna on your property, as long as:
                              • there will be no more than four antennas on the building overall;
                              • the size of any antenna is not more than 130 centimetres in any linear dimension (not including any projecting feed element, reinforcing rim, mounting and brackets);
                              • an antenna mounted on the roof does not stick out above the roof more than 300 centimetres above the highest part of the roof.
                              • COVENANTS LAND
                                • 15
                                #30
                                Originally posted by Xenobyte
                                I was looking at the tm 5400CI+Super and 1m motorised package for?209 but now im looking at Dreamboxes !
                                Silly question but how heavy is a motorised dish & motor ?
                                Hi buddy
                                They are not heavy really as you put it up in parts mount then motor and the hard part is the dish just do it on a nice day as wind is a bloody pain to hold the dish while your trying to bolt it on
                                Cheers
                                Cov
