solomend hd pvr 800
  • hooley
    • 470
    solomend hd pvr 800
    Has anyone here got one of these receivers??
    Solomend HD PVR 800 (Ali3602 solution ) Dreambox 800HD
    Im looking for a bit of help with it. Theres not much info online about it.
  • algamri
    • 11
    Solomend 800 pvr
    I have one of these, happy with the picture but could not get work using cccam ...
    If any body did get it working with cccam please advice.
    • hooley
      • 470
      I got mine working no problem these days. What do you want to know?
      • opsmonkey
        • 5379
        is this a DM800 clone or what.?? Or is it a box similar to the Spiderbox etc..?? Cheers
        • algamri
          • 11
          Hooley,
          The firmware I am using is as attched
          and I followed the attached file to load the cccam file
          please advice
          regards
          • hooley
            • 470
            Thats the guide i used when i got the box. What is your exact problem? Ill need more information.
            • hooley
              • 470
              Its how can i say it a dm800 lite. Does cccam fine,also can share i havent tried it mind. No plugins,no epg(now and next), no bouqets. I use it in my bedroom with a sly share.Does the job fine for the money
              • algamri
                • 11
                HOOLEY
                I HAVE FOLLOWED THE SHARING FILE AS ABOVE BUT COULD NOT GET THE THE RECIVER TO UPLOAD THE CCCAM FILE..
                EVERY TIME I DID FOLLOW THE SHARING METHOD AND TRY TO READ THE USB ...A MESSAGE AYS 0 FILE FOUND 0 FILE READ... IE IT IS NOT READING IT ..
                I WAS ABLE TO UPGRADE THE FIRMWARE THROUGH THE USB WITHOUT ANY ISSUES BUT COULD NOT GET THE RECEIVER TO READ TO CCCAM FILE FROM THE USB MEMORY STICK..
                SO I AM NOT REALY SURE WHAT ELSE I CAN DO..
                REGARDS
                • hooley
                  • 470
                  Pm me your email address and ill send on the cccam folder that i used. The box can be a bit picky what it reads.
                  • opsmonkey
                    • 5379
                    anybody got any good links where to buy.. cheers
                    • Djkane2007
                      • 5
                      Soloman HD PVR 800
                      i am having problem with this box, audio with HD channels not owkring then change audio with audio botton n get voices is going with the audio any idea how to fix this?
                      • algamri
                        • 11
                        Upgrade SOftware///
                        also you can use the Digital coex cable connection .. you should get sound
                        • algamri
                          • 11
                          managed to get the cccam working
                          hi hooley,
                          Managed to get the cccam working ... I had to buy a new memory stck... Not all memory stick work with this receiver.
                          Many thanks for all the help..
                          regards
                          • algamri
                            • 11
                            solome
                            This receiver could be the killer to the dmxxxhd.
                            it is so easy to use and freezing is almost vanished..
                            try this link to buy
                            • smuf54
                              can someone pass this info onto me as im having same issue with cccam being read from usb
