Solomend finally works great with motor and 22khz switch.
solomend hd pvr 800
use NewNigma and Enigma II and install the CCcam from the box, Just make sure its set up with the internet then and the dreambox will automaticly download it, It may also be you'r sim card, You could use the ferrari sim witch makes all drivers, Updates ETC work within a clone.
I find the Dreambox 800 a very good satellite box.
Regards,
Ellis.
Sat Boxes
Dreambox 500s.
Dishes
Sky minidish self fitted.Comment
What'chu talkin' about, ellis?use NewNigma and Enigma II and install the CCcam from the box, Just make sure its set up with the internet then and the dreambox will automaticly download it, It may also be you'r sim card, You could use the ferrari sim witch makes all drivers, Updates ETC work within a clone.
Regards,
Ellis.Comment
Ellis is getting realy mixed up with threads lately, damn haha !
Sat Boxes
Dreambox 500s.
Dishes
YaoXin Electronic CO.,LTD
the openbox s9 is more or less the same iirc
openbox s9 seams to have a good new update in the last few days
uk OPENBOX S9 HD PVR receiver - MaxSatellite ?99.99Last edited by the man; 17 October, 2010, 23:27.Comment
I got mine from Maxsat a couple of weeks ago and have to say was very impressed with speed of delivery. As far as I am concerned the Box is great. The build quality looks very good and there is certainly nothing flimsy about the remote. Its not that much different from my samsung remotes. (my openbox remote is slightly different from the one shown in the chinese adverts so not sure if it is a later model)
If u want cs without the major computing hassle associated with DM's then this is the box for u.VU Solo2 (clone) , Alsat GBOX V3000 positioner, 1.8m Precision motorised dish. Invacom twin 0.3 LNB, Image Blackhole 209 clone safe. Quad core Android TV box running XBMC and many other AppslComment
thanks for filesTry these for editing channel list. Just use the channel editor, other stuff not needed.
As regards the rebooting problem, plug out the lnb connection going to the box and power it up. Delete the channel that is causing the reboot and replace it with another of the same. Usually a few diiferent scans of the same channel. You can do this through channel mananger on the box.
It says Solomend but its the same as your box.
The file from the openbox ends on .dbs but this program does not support it.
However you can change de ending dbs to .abs and then open the file with this program.
It will suport it.
Then after saving you need to alter it back to .dbsComment
