hey just to update yh i changed over to the dk image. anyway i took the motor down it hasnt been right from i first got it coz it went past 80 and its not moving now. plus i set hardware limits and they dont work ether as well as going the wrong way. so im contacting vender 2morrow to try and get it fixed
got the dish up 2day but iv a big problem
thanks for the update mate.must confess I"ve only used TM motors and found them just about bullet proof.I"ve never heard of them going past the hardware stops.did you try using the manual button to check if went the right way.press once and hold in for west.press twice in quick succession and hold in for east.anyway post the outcome wont you.there is also a re-set button you could try,it needs a thin rod to go in the hole next to the led light.Last edited by dick b; 6 September, 2010, 11:34.Comment
yeah when using the manual buttons it went the right way the only prob its its stuck and not moving at all now.
so i contacted the seller he told me to mail to him and he get it repaired.
so i told him that i tryed to send it to 26 est and it went off the scale past 80 to the west b4 getting jamed, he then tryed to blame it on my dreambox sayin it wont work with a clone.
is this true coz i only ever heard of the clones not having enough power to move them not sending them the wrong way of the scale and stuff anybody know more about this?Comment
my 500 used to power a motor no problems.yeah when using the manual buttons it went the right way the only prob its its stuck and not moving at all now.
is this true coz i only ever heard of the clones not having enough power to move them not sending them the wrong way of the scale and stuff anybody know more about this?Faster than Faster
update
ok i broke my last mortor coz my recevier sent it past 80dergess last wk and it stop moving.
today i brought i new tm2600 again im having probs cant get the dm500 to move it where is should. sometimes its moves sometimes not but never to where i send it. tryed both diseqc 1.2 and usals.
tryed resit on motor and dreambox and changed image but no luck. i hope someboday can help me with thisComment
check you have the correct lat and lon settings,,, also you must get a good pic on 1west (bbc world news) "before" you look for other sats.update
tryed resit on motor and dreambox and changed image but no luck. i hope someboday can help me with thisFaster than Faster
I use multimap just put in your postcode and use the ones in the brackets.
Example below
Lat: 52:57:10N (52.95268) Lon: 1:07:24W (-1.1233)
If this was your Lat you would put in 52.952
For the Long 0.1123
If you do this and put in a decent set of bouquets you should be ok if you set it up in simple mode for usals.
Ive also used this on a clone dm 500 with no problems.
Hope this helps.
Andy.
Lat:52:57:10N (52.95268)Lon:1:07:24W (-1.1233)
Did you know?Multimap helps you:- Email maps and directions to friends
- Book hotels and cottages
- Find Wi-Fi hotspots
- Buy aerial photos of your house
- Locate petrol stations
I used to find my old dm500 would go all the way west if i tried to move it to a satellite that was not stored in when NOT using USALS.Comment
Example below
For the Long 0.1123
Hope this helps.
Andy.
ok i done like u said. i seemed to have got it going with usals but not sure if its the correct postion. ok iv got the motor on the ground i sent it to 42 east but it showing up 48 on the motor scale 28.2e shows up 33 on the motor, 16.0E shows up 19 on the motor 5.0w shows up as 5w ok on the motor and 30.0W shows up at about 32 on the motor scale is this correct or wrong to show up like this?Comment
it wasnt a pointless post as he said did the clones have trouble powering a motor,,,,Faster than Faster
thx yamar did u read my last post i think i might of got this usals going with this clone but im not sure if its going to the corect postion for the sats buy looking at the scale on the motor. can some1 check my last post and see if this is ok? plsComment
Have you installed your bouquet list to see if the dish goes to the correct satellite??
That should tell you if its correct.
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
