AS THE title says, is stv still not available on freesat any way at all ??
IS STV STILL NOT AVAILABLE ON FREESAT ?
STV on Freeview
I think STV is a regional program on Freeeview ~ It is FTA and is listed as 10.906 V 22000 5/6 on TP54 ~ Could also be on Freeview on the EPG upper numbers for regional ITV. -
STV on freesat
yes have got it on TP10.905V 21.991 i have just recantly give it a blind search after tweaking the sat positionComment
saltire u might start by saying what kind of freesat reciever u have,but with most recievers you would go in the menu >goto installation>pick your sat ,wich would be astra 28.5/eurobird for
you and strart a scan if this is finished you have to go trough your channel list to see if stv is there if not you might have to put in the transponder manualy "frequencie" but try the top part first. " i think there was already nice people trying to help you"Last edited by thijs; 3 October, 2010, 13:11.Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
its built into my panasonic plasma mate.saltire u might start by saying what kind of freesat reciever u have,but with most recievers you would go in the menu >goto installation>pick your sat ,wich would be astra 28.5/eurobird for
you and strart a scan if this is finished you have to go trough your channel list to see if stv is there if not you might have to put in the transponder manualy "frequencie" but try the top part first. " i think there was already nice people trying to help you"Comment
If you entered your Postcode correctly during Initial Setup I thought the local channels were tuned into the Freesat EPG in the correct position for you ?
But if not then....
Try TV - MENU - SETUP - Other Sat Tuning Menu.
and access the channels via the TV button.Comment
is there anywhere it says" manual transponders"or something simelar in the any sattelites menu
if there is put this in manualy transponder or frequencie 10.906
polarazation V
Symbol rate 22000
fec (if its there) Auto or 5/6
let us know how you get on or maybe ask the shop where you bought it if you can m8Last edited by thijs; 9 October, 2010, 14:10.Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
, i'm a bit of a newbie with freesat, can yiu explain how to do all this please ?
