situation is still as as in my last post but now i have telnet connected, still stuck though, 2 days solid now still joy.
itgate 220 not finding channels
I know it is a silly question but do you have dhcp ticked in your communication settings, plus i have had problems with this download and have to turn box off then back on and try again, keep trying a different set of bouquets until it kicks in, i find it very tempermental.
ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.Comment
thanx andiewill, i have dhcp on both router and itgate set to on, dcc says network ok between pc-itgate-router, ftp connected and telnet connected, tried downloading channels lists + cccam from blue panel all i get is the following,
install failed.please check available space.
i checked the var an its on 28%, all this is new to me and everyones help is very much appreciated, however this box it really starting to piss me off.?30 tuner i dont know whether its a dud coz i i cant install sod all on the box, i could have put the money towards a spider.Comment
As mep1 one say's ftp the rar ccam 2.14 files manually to the box and locate and install to var>etc....
Then press the blue buttoon twice on your remote and scroll down to add on manager, press the yellow button (manual), then in the drop down menu select your CCam and install.
Your nearly there you just need the cams which i did not realise until i read through the post's again.
right lads first of all another thank you for the help, i sent edg nemesis to the itgate via dcc, itgate rebooted(so must be talking) dont know where to locate this, also i have CCcam 2.1.4 on pc tried to send this via dcc, via install addon package tar.gz but when i locate the folder with CCcam 2.1.4 in it says no items match your search, also when i go to manual addon install via bluex2 yellow buttons only addon option i have is cpanel.tar.gz. getting on my tits this is now.Comment
i have managed to ftp CCcam config and edg nemesis 4.4 to the var/erc folder on the itgate via dcc, also a satellite xml list with just hotbird and astra1, the sat xml works as the only 2 sat available to me are the above mentioned. still cannot get any services even though i have a lock on strong signal transponders. i still have uk.ur 7.9 image working as i cannot install either the CCcam or edg nemesis( manual download panel only gives me the option to d/load cpanel.tar which is already installed) i am at a loss to be honest getting there slowly dont know if i am doing the right things or not, but i have been 4 days solid at this know and getting seriously f***ked off, anymore help lads before i throw it out the window. p.s .best wishes to big mac enzo maccarinelli after his knockout defeat last night, see you when you come home mate.Last edited by allivnotsa; 19 September, 2010, 18:18.Comment
thanx mept1m, right i have downloaded v8 ireland folder to my desktop which contains,
tgm220 uboot img,
tgm220 update img,
so what do i do next? and what is a dual image?, thanx.Comment
OK
tgm220 uboot img = Use this image when your box goes T+Ts up.
tgm220 update img = Use this image to update your box to V8
Dual image means you can use the same image for cable and sat, just factory reset your box once the image is loaded, and the image will pick up your tuner that is in the box.
i ftp the image to my box, done a factory reset and the box rebooted with the uk/ur 7.9 logo still there and in dcc telnet telling me incorrect password now ? help....Comment
