itgate 220 not finding channels
  • mept1
    • 346
    #31
    I change my password from blank to itgate ,in itgate control centre,could never ftp with blank.
    • allivnotsa
      • 43
      #32
      i have done what was advised to do, sent v8 ireland image via ftp in dcc to var/etc folder, factory install and 7.9 image is still the boot image with no option in blue panel to manualy install anything other than cpanel. tar, tried a scan for channels on 16 east 91 transponders no services.what next?
      • mept1
        • 346
        #33
        You may have thought you sent it,... but it for ever reason never arrived,...try using itgate contol centre? it,s really simple.you obviously have connection,...15 mins and you should be good.
        • allivnotsa
          • 43
          #34
          thanx mept1 i have itgate control centre on my pc can you tell me how to do it?
          • mept1
            • 346
            #35
            ok,..based on cc 2.4 open cc,...first config ,obviously make sure ip on your box is the same as in cc window,...ie:192.168.1.108,..box and centre should match.
            login info
            reciver ip:eg above
            password:blank
            change password
            new password eg:itgate
            confirm new password:itgate:
            reboot your pc and box,...DONT FACTORY RESET this will clear your new password.
            open cc again.
            fill in the boxes again
            reciver ip:192.168.1.108
            password: itgate
            go to update the rest should be self explaning
            good luck
            • allivnotsa
              • 43
              #36
              cheers mept1 i installed uk/ur 8 ireland no probs, i then installed edg memesis 4.4, downloaded a channel list from blue panel but still no channels, i have cccam 2.1.4 on my pc, which include the following,
              cccam.armeb
              cccam.armeb.eabi
              cccam.cfg
              cccam.mipsel
              cccam.ppc
              cccam.x86
              cccam.x86_64
              change log
              what do i ftp to the itgate and should i use dcc or itgate centre? reading replies earlier in my thread installing this should give me channels is that correct?. thanx again.
              • mept1
                • 346
                #37
                why are you using edge nemis4.4? when all you require was the v8 imiage.
                after you flashed it all that was needed was to factory reset the box,then set your password again via itgate control centre
                with v8 on,all you had to do was download cccam 214 followed by the cccam cfg via blue button.
                you then need a ftp client as mentoned before,..then when you ftp into the box the var/etc then edit the config file.
                you are making this far more complicated than it is.
                so to sum up,.....flashing and editing password is done via itgate control centre
                downloading the cccam214 and config file is via the blue button
                editing the config file is done via a ftp client.
                good luck.
                • allivnotsa
                  • 43
                  #38
                  i have downloaded the cccam 2.1.4 file as said earlier, ftp this to the var/etc also tied sendind to the var/temp and sweet f.a. happens, nothing in manual install bar just cpanel tar.gz,tried this on v8 ireland and edg nemesis, mept1 you mentioned about editing the cccam config if you mean change to 755 i tried that,if not would you tell me otherwise, also as i asked earlier do i need cccam to view free channels or is this new tuner a dud ? i am getting closer thanx to all you guys, i dont mean to be a pain in the arse but linux is new to me.
                  • mept1
                    • 346
                    #39
                    You dont need cccam for freesat,....do you not even get 1 channel?if not,. somthing deffo a miss,. either your connections or your tuner.
                    regarding cccam214,. why dont you just download and install via blue button,..no need to ftp.
                    • allivnotsa
                      • 43
                      #40
                      hi mept1, i have no channels, was told earlier in thread that i needed to install cccam to get channels, as when i scan for instance hotbird i get lock and strong signal strength and quality but the scan returns with no services found, my tm6800 no probs at all. as for downloading the cccam i have no option on the edg nemesis its not in the addon/plug in list to download, the v8 ireland has cccam 2.1.0 option but just hangs on dowloading.
                      • shamusbhoy
                        • 66
                        #41
                        Like mept1 said no need to ftp anything if connected to the net, I would do a factory reset to clear var folder of any crap thats in there, run through your sat setup then straight to blue button and the option to download cccam and a channel list like vhannibal should be there.The only time you need an ftp client is when you want to manually change things or edit cccam.cfg but thats a different thing altogether.
                        sigpicSubbuteo say no to newco
                        • allivnotsa
                          • 43
                          #42
                          hi shamusbhoy, i just done a factory reset edg nemesis 4.4, dowloaded vhannibal motor 18-09-2010, set my motor up scanned astra 2 lock on transponders (85%) but no services, also there is no option to download cccam in blue panel. like i said mt tm 6800 no probs picking up channels.
                          • mept1
                            • 346
                            #43
                            you only need to install cccam to view preminum channelswith clines hence the "C" but as shamusbhoy thats a difrent ball game.
                            if i was you i would scan 28.2 and view freesat,..... SEE IF THATS VIEWABLE
                            • allivnotsa
                              • 43
                              #44
                              just scanned 28.2 east again 107 transponders no services, strong s and q though.
                              • shamusbhoy
                                • 66
                                #45
                                I thought you were running ukur v8, if you have vhannibal on press ok then green for satellites scroll to 28.2 ok again then scroll to bbc and see if it works.This is for ukur image but nemesis should be roughly the same.
