itgate 220 not finding channels
  • allivnotsa
    • 43
    #46
    i got the same results on both ukur v8 and edg 4.4 signals romping in but no services, i t must be a dud tuner.
    • shamusbhoy
      • 66
      #47
      on the vhannibal channel list the services are already there try scrolling to 28.2 services and see what happens.
      sigpicSubbuteo say no to newco
      • allivnotsa
        • 43
        #48
        i have ran through the vhannibal list on 28.2 and i get strong signal and quality but the screen is blank. read a few posts on here and other forums about the same problem but no definitive answers to solve it.
        • mept1
          • 346
          #49
          If your getting a strong signal and quality,....tuner must be ok!!
          • allivnotsa
            • 43
            #50
            yeah mept1 thats what i thought, but something is not right.
            • allivnotsa
              • 43
              #51
              anyone else have a solution?
              • allivnotsa
                • 43
                #52
                when running through the blank channels i am getting the message switch unkown error.
                • mept1
                  • 346
                  #53
                  ok when you press bouquets on the remote control theres 4 options,select green,what do your first 3 options give you?
                  IE:04 astra/eurobird 28.2-new found (0)
                  • mept1
                    • 346
                    #54
                    or try this press bpuquets then blue button,scroll down to astra-eurobird 28.2,then scroll onto freesat,..click on bbc1,..see what happens
                    • allivnotsa
                      • 43
                      #55
                      when i press bouqets the 3 options on 28.2e are
                      new found(0)
                      provider
                      services(676),
                      then when i go to bbc 1 on freesat there is nothing.
                      • shamusbhoy
                        • 66
                        #56
                        Where it says services(676)scroll down to it and press ok, you should find about 20 BBC 1 channels,I would think some of them should work.
                        • allivnotsa
                          • 43
                          #57
                          morning shamusbhoy, i have already tried that on 28.2e plus loads on 13e, 19e ,16e etc, dont know what to do next, could there be a fault with the box itself and not the tuner?
                          • mept1
                            • 346
                            #58
                            Did you try press bouquets then blue button,scroll down to astra-eurobird 28.2,then scroll onto freesat,..click on bbc1,..
                            cos when i use the yellow button theres services(676),,..nothing is viewable to me either.
                            • shamusbhoy
                              • 66
                              #59
                              Double check all your connections from box to tv and give it a reboot.
                              • allivnotsa
                                • 43
                                #60
                                already did what you suggested, rebooted many times connections all ok.still same result no pic no sound great s and q.
