Latest firmware for openbox S9 / S10
  • k114l3d
    • Nov 2011
    • 13
    #166
    Originally posted by nuky
    The new firmware / Software is attached, if any one can test and share the experience that would be great.
    also is this the 09/11/11 firmware? i will test this tonight if someone confirms its newer than the 15/09/11 firmware
    • t0nito
      • Nov 2011
      • 10
      #167
      Hi I just installed so far everything seems the same except that now there is a avatarcam setting.
      • k114l3d
        • Nov 2011
        • 13
        #168
        i installed it too, and i can confirm the avatar cam setting is there. however what does this actually do?
        another thing is the favorites menu goes back to being in a single list, rather than the multi column list as in the 09/11 firmware.
        not too sure if this is the latest firmware??
        • Manic01
          • 5117
          #169
          Avatar cam is for non european settings I think.
          • t0nito
            • Nov 2011
            • 10
            #170
            I purchased this receiver very recently and the channel list with the firmware that came with it only had one column. When I installed the september firmware it had 3 columns I was getting used to it and now there is only one column again. But atleast on the single column there are more charaters and it's easier to see the channel name. Maybe that's why they reverted back to one.
            • ALCASIM3
              • Nov 2011
              • 4
              #171
              New born to openbox s10
              Hi, Just got new s10, but had no network function. took cover off found ethernet card loose on PCB. Hoping your advice for latest firmware download does the trick,Thanks.
              • slugworth
                • Nov 2011
                • 1064
                #172
                The s10 has no ethernet card.
                The ethernet components are soldered on the mainboard.
                • bulldog123
                  • Dec 2011
                  #173
                  do you put the usb in first and then reset to factory settings for openbox s9 then upgrade by usb
                  • ALCASIM3
                    • Nov 2011
                    • 4
                    #174
                    Newbie,updated latest firmware for s10 but need CCcam.cfg
                    Hi, New to this freesat stuff. Just got S10 but with no Network Function as part of deal. Took cover off,found above card loose in PCB slots. Bingo ! Downloaded latest firmware, Bingo ! Now stumped, no "CCcam.cfg file found". Tried getting it, Like holy grail finding it. What am I doing wrong , any help ? Cheers.
                    • darvash
                      • Aug 2009
                      • 51
                      #175
                      Hi friends
                      There is new software dated 17/11/11 on the first page.
                      Tested my self on S10 and working smoothly. Only thing to remember is reboot stb after scaning channels.
                      *****Don?t argue with idiots. They drag you down to their level and beat you with experience*****
                      • lombard
                        • 793
                        #176
                        Hi, i recieved a Openbox S11 today, updated with this OPENBOX_S10_111117.rar, working fine my chip ID is 10AA, also i noticed the firmware that came with openbox s11 had avatercam feature with this update its gone ??
                        • slugworth
                          • Nov 2011
                          • 1064
                          #177
                          save
                          Originally posted by lombard
                          Hi, i received a Openbox S11 today, updated with this OPENBOX_S10_111117.rar, working fine my chip ID is 10AA, also i noticed the firmware that came with openbox s11 had avatarcam feature with this update its gone ??
                          you should always save the firmware 1st before doing any upgrade,just in case. I think there was some firmware labeled as avatarcam floating around for the s10
                          • pisciolone
                            • Dec 2011
                            Box rebooting continuosly
                            Hi, I am a newbie. I wonder if somebody can help please.
                            I have installed the new firmware but the receiver keeps rebooting as soon as I use the remote control. i have tried to reset by switching the off for 5 minutes but no joy.
                            Thank you for your help
                            • xbyte
                              • 117
                              #179
                              no new software for s9 ? looks like the producers abandoned the s9 :P
                              i want to upgrade the cccam, to make it able to read a card and share it to a network, at the same time as i receive other cards from the same network as i share too.
                              i havent had time to look at this yet, but i wonder if the flash files are encrypted or packed ?
                              https://chipster.no
                              https://www.youtube.com/c/KimFreding
                              • slugworth
                                • Nov 2011
                                • 1064
                                #180
                                12-2
                                dec 2 is the latest for s9,pretty fresh
