Openbox S10 Front of Box saying ON ??
  • claretfan
    #76
    Fix needed
    I have the 'no display ' problem let's hope I have luck with the software kndly posted here.
    • Jack Jumpin
      • Sep 2009
      • 31
      #77
      I had a s10 showing oN so tried downloading the fix, but couldn't get it to connect using usb to serial adapter, then I notice after a few tries it was showing boot instead of oN, I take it if you turn on and off a few times if you have the oN issue that eventually it will goto boot ?? When in boot mode it came up the skybox logo but I could do nothing with the remote then turn off and on and it loaded to a channel, so I have now flashed anonymous hacked firmware and all is well.
      So my question is does the oN actually mean it is broken, or is it recoverable with a few reboots ????
      Cheers
      JJ
      • slugworth
        • Nov 2011
        • 1064
        #78
        mine said on,then the next time I cycled power it was dead.
        You were lucky and the firmware was just a little corrupt.
        • systemseiko
          • 40
          #79
          From experience i have flashed about 10 of these boxes with different issues, i ran into problems with 2 boxes that i could not connect via a null modem USB cable.
          Please only carry this out if you are Electrically competent.
          Remove the rear cover via 3 + head screws.
          Disconnect each module 1 at a time and attempt reflash.
          In my case i had a faulty RJ45 network port, and a faulty display panel.
          I replaced both with spare parts from box a bought with faulty main board off fleabay and was able to bring back to life.
          • slugworth
            • Nov 2011
            • 1064
            #80
            firmware
            if you kill it with firmware,it's a firmware issue.
            If the box is used and dead,anything goes.
            It could even be a bent pin on the cam connector.
            • mannair
              • Jan 2012
              hav an S10 with "no display" on front panel.I upgrade it using EromUpgrade and now S10 say "boot" on front panel. plz help me recover my S10
              • slugworth
                • Nov 2011
                • 1064
                #82
                ry
                keep trying
                • zpatel1970
                  • May 2011
                  #83
                  hi anyone can help i have s10 hd box it worked 4 few days now showing 2 lines on display, tryed flshing difrent images still same.
                  • slugworth
                    • Nov 2011
                    • 1064
                    #84
                    I've only seen that after loading old solomend 800 firmware.
                    I recover via rs232 and loader v2.0.0c
                    • netpsa1
                      • Jan 2012
                      DB help
                      Originally posted by DW190
                      I have used a laptop with usb to serial for six years without any problems.
                      Dbox?????????? The best way to flash the dbox was to have it switched on hit the start on the loader then quickly switch off and back on for a 99% success.
                      What is the loader you use to flash db?
                      Mine is dead again.
                      tkx
                      • satman2
                        • Aug 2009
                        • 36
                        #86
                        i have org.box and thats (DEEP_C2DS2_CMT_1112130641.abs) killed yesterday
                        but why killed org box? cannot understand
                        • Tomukz
                          • Mar 2012
                          have s10 killed want to try to get it back but some how my pc cant connect any more through com1 port. even today it was working and now stoped cant find corect port can anyone help to sort it out as seen somewhere how to do it but cant find it anymore
                          • samuidiv
                            • Dec 2011
                            #88
                            open box flash reset ? which port ??
                            When I've done it the fail took about what seemed like 20 seconds to appear.
                            When you click next try different delays before powering the box. ie. 1, 2 or 3 second..
                            which port ( com ???? )do I use ?? the erom upgrade always shows " open serial port failed " Please reset target.
                            • slugworth
                              • Nov 2011
                              • 1064
                              #89
                              make sure you even have one.
                              com1 is the default.
                              • efunss
                                • Apr 2012
                                mine s10 also same problem, need to try to reflash...
