I had a s10 showing oN so tried downloading the fix, but couldn't get it to connect using usb to serial adapter, then I notice after a few tries it was showing boot instead of oN, I take it if you turn on and off a few times if you have the oN issue that eventually it will goto boot ?? When in boot mode it came up the skybox logo but I could do nothing with the remote then turn off and on and it loaded to a channel, so I have now flashed anonymous hacked firmware and all is well.
So my question is does the oN actually mean it is broken, or is it recoverable with a few reboots ????
From experience i have flashed about 10 of these boxes with different issues, i ran into problems with 2 boxes that i could not connect via a null modem USB cable.
Please only carry this out if you are Electrically competent.
Remove the rear cover via 3 + head screws.
Disconnect each module 1 at a time and attempt reflash.
In my case i had a faulty RJ45 network port, and a faulty display panel.
I replaced both with spare parts from box a bought with faulty main board off fleabay and was able to bring back to life.
I have used a laptop with usb to serial for six years without any problems.
Dbox?????????? The best way to flash the dbox was to have it switched on hit the start on the loader then quickly switch off and back on for a 99% success.
What is the loader you use to flash db?
Mine is dead again.
have s10 killed want to try to get it back but some how my pc cant connect any more through com1 port. even today it was working and now stoped cant find corect port can anyone help to sort it out as seen somewhere how to do it but cant find it anymore
