Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • beats2006
    replied
    Originally posted by eziorec
    I've a new skybox m3 died (only red light when powered and no remote controls' effects...)
    Tryng to refresh firmware by rs232 null and erom upgrade 2.0.0c 2009-05-22...
    FW: SKYBOX_F3_M3_wifi_3601HD_CMT_1209040733.abs
    Set stb memory error
    I think COM1 settings are ok... I've tried several possibilities...
    Can I try something else or sendig back the box to the seller is better ?
    Thanks, byes,
    Ezio
    Ok I was having the same problem and just fixed it finally after a lot of trial and error heres what I did -
    downloaded http://www.digital-kaos.co.uk/forums...de_8mflash.rar
    then downloaded some older firmware -
    SKYBOX_3601hd_CMT_120820071a.abs
    (if you search google you will find it)
    Then I plugged the box in and attached the null modem cable,
    opened up the erom upgrade folder and ran CONFIG.BAT
    then ran EROMUPGRADE
    Selected the firmware I downloded
    Ticked Include Bootloader
    Clicked next
    when it says-
    synchonizing stb
    Reset target
    I unplug and replug the power cable out of the back of the box quite fast it will then let you carry on and recover the box
    once recovered you can update to a later firware via usb or the X3 Lan tool.
    hope this works for you as I was pulling my Hair out yesterday
    Leave a comment:
  • slugworth
    replied
    sell it for parts
    people buy them for the power supply and other goodies
    Leave a comment:
  • dkeeper
    replied
    I think it can't be fix anymore,i already send the box to the shop to check the power supply unit.they said the power supply is working and mention maybe the board is bad.look like have to buy a new one huh..
    Leave a comment:
  • slugworth
    replied
    unless it's just a bad power supply,there isn't any user serviceable parts.To verify a bad power supply you would have to measure all the voltages.
    Leave a comment:
  • eziorec
    replied
    Yeahman this in my question too...
    How can the hardware problem be fixed (is it possible ?) ?
    Thanks for your help.
    Leave a comment:
  • dkeeper
    replied
    slugworth,can the hardware be fix?
    Leave a comment:
  • beats2006
    replied
    my skybox M3 is stuck on L100 on the display & no picture on the tv I have a null modem cable any ideas how I bring it back to life?
    Tried Upgrade pvr800 hd tool with captains bigger log.abs but get SET STB Memory Error when trying to flash?
    Leave a comment:
  • wroenaldinho
    replied
    mine does the exact same, cantget past stb memory error on skybox f3
    Leave a comment:
  • dkeeper
    replied
    i already try to this method but the message " Set stb error.Click 'back' to try again." i think my box is already dead as it can be..
    Leave a comment:
  • slugworth
    replied
    red light is a hardware problem
    Leave a comment:
  • rigsby71
    replied
    What have you got to lose.
    The info is here to help you recover such dead boxes.
    No point in asking about it, just do it.
    You have nothing to lose really.
    I have one to do myself.
    Leave a comment:
  • dkeeper
    replied
    Hi all,i have the same problem like eziorec..my S9 also show only red light when powered,no remote controls effects and did't show " ON " at the display..is this method work for me?thanks
    Leave a comment:
  • db001g6598
    replied
    i bought sky boxf3 put all the channels ,but still scrambled chanels,put firmwere in still the same,can anybody help
    Leave a comment:
  • eziorec
    replied
    Thanks, byes,
    Ezio
    Leave a comment:
  • slugworth
    replied
    the past 103 posts just did
    Leave a comment:
