Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • micky23
    • Jun 2014
    #736
    Hi, got a dead F5S, and having read thru the whole of this thread, which is brilliant, im still stuck, "STB Memory error"
    (IF it comes with set STB memory error please run config.bat file (Located in folder you have downloaded and unzipped) ) before running loader
    Can anyone explain how to run the config.bat file successfully , then maybe i will get passed this point
    Cheers in advance
    mike
    • P&D
      • 2684
      #737
      Hi what cable are you using Null or USB
      If USB are you using the correct com-port ??
      also which software program there are a few
      • micky23
        • Jun 2014
        #738
        Null via usb adapter on my laptop or Null direct via serial port on my PC, same result on both
        used several eprom update versions 2.0.0c and 2.0.1 and every version of .ABS i can find for original F5S and Clone F5S
        but i still end up here, with the stb, also been into device manager and slowed the buffer rate right down,
        and it still wont go
        so the qusetion was how do u run the config.bat file
        mike
        • P&D
          • 2684
          #739
          so the question was how do u run the config.bat file........ never had to
          Use one of these loaders.....
          erom_upgrade_8Mflash.rar
          Upgrade_PVR800_HD_Tool.rar
          Firmware below..........update20150713.zip
          Check your computer is using the correct com port.....see 1st photo com port
          this must match this com port see 2nd photo ....
          eprom update com port
          Tick boot loader & try again
          You now have all you need to get the box back up & running
          If everything works & then you get file mismatch you have a clone box
          which is a different firmware
          • CrAcKeDuPII
            • Oct 2013
            • 19
            #740
            Hi P&D,
            Thanks for all your help on trying to bring the boxes back to "life."
            I've got an old F3 that is constantly rebooting after a recent favourites update by USB. This isn't the first time I've seen this happen either. It eventually just stays on L100. Anyway I have used the null modem cable and have managed to complete the process of reloading the software several times, but the same fault persists. Just wanted your opinion......time to give it up as a bad job? BTW I have just about every loader and all versions of the software, but none seem to cure the problem.
            Cheers,
            CrAcKeDuPII
            • P&D
              • 2684
              #741
              Hi with the F3 are you using the correct firmware ??
              are you also ticking boot load on the screen where you load the firmware ??
              The last firmware for the F3 is below.......this is the one i always use
              where abouts are you if close i can do the box for you 10 mins top's
              or see DW190 post here ......http://www.digital-kaos.co.uk/forums...=1#post2189552
              • snowie14
                • Jul 2015
                • 12
                #742
                Just wondering if someone could help me , I have a v5s open box and my father is looking for a box like this but I see that a newer version the v8s is out now ,would I be best off going for that box is there much of a difference and I guess it's the same set up , any help would be greatly appreciated
                • dazza78
                  • 178
                  #743
                  I've got the v8s and mine is stuck on strt booting screen where it says openbox, so I'm assuming I need to buy a cable ?
                  Thanks in advance only had the box a yr and already had to sort anew server out after being scammed
                  PS3 ID= thebeast-666
                  • portvalefanjosh
                    • Dec 2013
                    • 101
                    #744
                    Anyone help me out please i had my friend bring her v8s box which was stuck with load on the front, so i flashed it. And now it dont do nothing no lights comming on nothing? Any ideas? thanks josh
                    • smspop
                      • Apr 2009
                      • 5
                      #745
                      Originally posted by Hadron
                      Sounds similar to the problems encountered in this thread:-
                      It gets interesting from post #65.
                      Anyone point me in the right direction for the above missing thread, I'm having the same issue with an S5f
                      Thanx.
                      • Hadron
                        • 2102
                        #746
                        Thanx.
                        It seems to have moved since I last linked to it.
                        Here is the new link.
                        Read from post#65 for the solution.
                        How many people have been using there f5s with no problems then as soon as they update firmware or in my case used the lan tool we get a box that loads up for a few seconds then freezes? Disconnect sat feed and all ok? All of a sudden we have suspect feed? Not saying that it doesn't help but why all of a sudden is the
                        • patch1gizmo2
                          • Sep 2014
                          • 5
                          #747
                          thank you for this much appreciated
                          • inaminute23
                            • Sep 2013
                            • 16
                            #748
                            Hi, can you install channel lists through this cable?
                            • Hadron
                              • 2102
                              #749
                              Nope. It's for flashing (or dumping) the firmware only.
                              • inaminute23
                                • Sep 2013
                                • 16
                                #750
                                Cheers mate
