Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • inaminute23
    • Sep 2013
    • 16
    #751
    Hi, does anyone know what cable can be used on a windows 10 laptop (ie usb to rs232)? If not windows 10, then which operating software? I know windows 7 works on my desktop
    • sanchezjones
      • Nov 2015
      • 15
      #752
      ive tested on win7 and also on win10
      • inaminute23
        • Sep 2013
        • 16
        #753
        Is that with a laptop?
        • inaminute23
          • Sep 2013
          • 16
          #754
          Got f5s with the dim 8 problem. Anyone got any ideas? Tried several loaders, but with no luck. Not tried a different psu, but it does work on my own f5s box. Is it still worth trying another?
          • benijofar
            • Apr 2015
            #755
            Normally when the dim red light is on and a figure 8 shows it means the EPROM chip has failed.
            No fix so a bin job.
            • inaminute23
              • Sep 2013
              • 16
              #756
              Cheers mate, thought that would be the case
              • inaminute23
                • Sep 2013
                • 16
                #757
                Please help. I have a v6 box stuck on load, but when i try to flash, to the point where i turn the power on i get the dim 8. When i cancel the upgrade it thenreverts back to be stuck on load. Any ideas???
                • BJTT
                  • 223
                  #758
                  hi darvash thanks for the useful info but I've noticed that when said box's go down particularly clones
                  like F5's for example & I know they are clones because after opening them up they don't have a
                  separate power section inside anyway it tends to be the front display gadget/device the one which
                  displays the channel numbers/on-off display column is the part which is not working @ all which
                  makes said box FUBAR & door wedge material however thanks for the useful info my Man & a
                  happy new year to you all
                  • radebla
                    • Feb 2016
                    Hello. First, sorry for my English.
                    I have a openbox s9 HD pvr.
                    My problem was that my S9 don't boot and always show in the panel a red led.
                    I read all post and tried a lot of ways to revival receiver but always shows error STB...
                    My solution was that my power supply was bad. C11 is 10V and 1000microF. I change him for a new condensator and... all works fine!!!
                    My problem was only the power supply don't firmware.!!!
                    I hope that my experience helps someone.
                    Cheers.
                    • inaminute23
                      • Sep 2013
                      • 16
                      #760
                      Hi, anyone got a link to cloned firmware for an f3? It's stuck on 97, it seem to re-flash fine, but depending which firmware i use, it either stays on 97, loads to 97 and then loops or sticks at 97 for a short while and then goes to E001. Any help would be greatly appreciated!
                      • patq19671
                        • Feb 2016
                        cheers for this will give it a go
                        • lmprintz
                          • Jun 2015
                          #762
                          can someone send a link as to where i can buy the correct rs232 to usb cable to flash openbox v8s thanks using laptop and windows 8 to do it with
                          • cwaite
                            • 360
                            #763
                            You can get the Null Modem Cables from eBay, I have tested these below and they worked for me!
                            Serial RS232 Null Modem Cable - DB9F to F - 2m
                            and if you dont have a serial port on your computer/laptop you will need a USB to Serial Converter (below).
                            PLEASE NOTE MOST COMPUTERS SOLD IN THE LAST 15 YEARS OR MORE PROBABLY WONT HAVE A SERIAL PORT, SO THERE IS A GOOD CHANCE YOU WILL NEED ONE OF THESE.
                            Prolific PL-2303HXD USB to RS-232 Serial Adaptor Compatible Windows 10 8 7 Vista
                            Hope this helps.
                            If you need help installing channel guides or have a problem, take a look at my video guides
                            https://www.youtube.com/playlist?lis...GHAAdpsKXqtadC
                              Ok please answer me this ?? WHY ON EARTH WOULD YOU WANT TO BRING ONE BACK TO LIFE ???? it's a blessing in disguise
                              • P&D
                                • 2686
                                #765
                                So it can Die again & you can buy some more paracetamol.....
