Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • walf
    replied
    Hi guys,
    Ive read all 29 pages and this is where I am at...
    I had a dead skyboxf3 (not switching on,no lights,nada). I downloaded the Erom upgrade 8mflash and ran the Eromupgrade program and used a frimware that looks the same as the other box I got at the same time. The program ran through well but now the box is just on constant loop. I'm close but not quite over the line.
    Any suggestions?
    Leave a comment:
  • Skippy316
    replied
    [QUOTE=Lfcexiled;1665486]Just wanted to add, may be helpful....
    My Skybox F3 got stuck in a loop on boot up whilst I was trying to update the channels from AJ's post so tried t update the firmware using the first post of this but kept getting the 'stb memory error' when using the eeprom in the package for download in the OP so had a look around the forum and found this post:
    and that software worked a treat!
    One point though, I found that if I tried to install newer firmware the box just stayed dead so went back to my original firmware and it was golden.
    Thanks to the original posters for saving my box.
    I tried all the other things to get my skybox f3 back up after it bricked used this info and got it back up straight away cheers mate
    Leave a comment:
  • cluney
    replied
    theirs no error just keeps loading up to L100 then starts again, as for usb convertor these laptop don't have them now is an other way to re flash them, i know this sound thick but what firmware am I it use is that the same firmware I used on usb stick
    Leave a comment:
  • P&D
    replied
    Everything is in this thread...i know there are 29 pages.......the answer to your question is to start at page 1...
    where the software is that you need & the correct cable....this will also show you the errors you may or may not get......
    This will also save you asking 100 questions & getting no where
    sorry to sound harsh but reading is knowledge.....every question you will ask has already answered in this thread
    Leave a comment:
  • chuckberry
    replied
    Hi guys im new to this i got a f3 box box it froze whilst doing a scan i turned it off at the power now it wont come back on no lights or power help please
    Leave a comment:
  • P&D
    replied
    Use the correct cable mate....NOT the usb one
    Leave a comment:
  • cluney
    replied
    hi newbie here got to section 5 where it say turn on box didn't do not thing until remove usb from laptop I have f3 have checked where usb goes to com16 any ideas please
    Leave a comment:
  • P&D
    replied
    Originally posted by nokmond
    What does 'synchronising stbs, etc' mean? That's all I'm getting while trying to recover my f5 box.
    Sounds like wrong cable or wrong software
    Leave a comment:
  • P&D
    replied
    Originally posted by Laurence89
    I use the EromUpgrade program and then I select the right firmware. And then it gives that error message.
    Gives what error ??????
    you say "If I turn on the box it does do the Checking STB and then says Done" yes after this are you loading the firmware & then downloading it to the box ????????
    If I turn on the box it does do the Checking STB and then says Done = does not mean the box has been flashed
    Leave a comment:
  • nokmond
    replied
    Leave a comment:
  • Hadron
    replied
    I use a null modem cable. Without the adapter (small orange thing) it doesn't do anything. Same if I remove the adapter. Nothing works. With or without adapter. I don't know what to do anymore. Can not make a connection
    Still don't know what the small orange adapter is, but providing you are definitely using a null modem cable (and not a standard serial cable) connected straight to your pc's RS232 com port, then no adapters are needed.
    Do you have a link to one of these adapters (are they sold on Ebay?).
    Leave a comment:
  • Laurence89
    replied
    Originally posted by Hadron
    I'm confused! What do you mean by null modem adapter?
    If your pc has a real com port, then all you need is is a null modem cable.
    Leave a comment:
  • Laurence89
    replied
    Originally posted by P&D
    Hi instead of using EromUpgrade file use a firmware file to flash the box......
    SkyBox | SkyBox
    Leave a comment:
  • Hadron
    replied
    ...(I am using a real com port and null modem cable with null modem adapter.)
    Leave a comment:
  • P&D
    replied
    SkyBox | SkyBox
    Leave a comment:
