Using a cheap USB to serial adaptor is a bit hit & miss, especially if you are using W7. For under ?2 it may be worth a risk. The Aten UC-232A gets excellent reviews on the Amazon website. It obviously costs more than the cheap Ebay ones.
[ame="http://www.amazon.co.uk/Aten-UC232A-USB-Serial-Converter/dp/B000J3OK7C"]Aten UC232A USB to Serial Converter: Amazon.co.uk: Computers & Accessories[/ame]
I bought one of these myself a few years ago, but haven't used it to flash an openbox yet.
Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
Leave a comment:
hello all i dont have a rs232 port on my pc. will a usb to rs232 work or will i be wasting my money. i have on a red light on the box. on the s10 kind regards mr youngLeave a comment:
my open box dead can i use a usb to null modem as my pc is 15 pin portLeave a comment:
rs232 null modem cable
hi sorry for my ignorance but what does this cable look like ,does one end have a usb and the other have a 9 pin connection ,my pc has a 15 pin port what do i doLeave a comment:
Dead S11
Most modern PCs have COM ports on the motherboard. Just need to find a com port bracket from your local PC supplier if you dont have a spare lying around.
Anyway - have connected a dead S11 - given to me by a friend. It appears to connect via RS232 as it detects when I switch it on. But will it not upgrade if I do not have correct firmware as I do not know if its original or clone. Any help on identifying the right firmware ?Leave a comment:
CANT FIX OPENBOX
I GOT AN OPENBOX SD HDR PVR AND SUDDENLY IT STOPPED WORKING FRONT LED WONT TURN ON AND IVE TRIED STB EROM UPGRADE AND IT KEEPS SHOWING SET STB MEMORY ERROR... I NEED HELP!!
THANKSLeave a comment:
Both my Skybox F3 and PC have male serial port connectors, so will a cable like this work?
Startech Null Modem Cable - DB9F - DB9F 10FT (3m) | Ebuyer.com
It's Female to Female
EDIT: Also seen this: http://www.ebay.co.uk/itm/USB-to-RS2...item25798ba97a It's USB makes it much more universalLast edited by elrasho; 9 February, 2013, 18:37.Leave a comment:
open box s11 not responding with Com port
I see many talk about openbox not responding with com port or STB memory error in recovery dead process in this forum but until now not yet good information came out,why box not responding
I test my null modem cabel and power supply and pc with other openbox and working very well.
Tried after many days and hours box not yet responding.
Mybe hardware damage insite the box.
any information welcome
RegardLeave a comment:
pc with real com port,null modem cable,proper loader,don't turn the receiver on too fast- are the basics.Leave a comment:
How many times did you try?
For me it worked first time, but for others they have had to try a few times before it would work. Try leaving your box for different amounts of time before switching it on.
Also make sure you actually have a null modem cable rather than a standard serial cable.Leave a comment:
after i upgrade firmware using erom upgrade, system still download after 1 hour. just show:
synchonizining STBs
please reset target!!
how can i solve this problem? anybody can help me to solve this situation....tq very mushLeave a comment:
Leave a comment:
