Hi same thing here updated with latest channel list, done it quiet a few times before with no probs ,tp abs file loaded ok did the reboot and just said on the display (LOAD) and is stuck there ,have no idea how to recover the dead box ,thought it can only b a bug in the channel list update if its happened to other people. any help would be great,just done some research and now think it may be a dodgy flash drive
exactly the same thing here m8, stuck on 'load' after the channel update, looks like my box is bricked....marvellous.
Tryed recovery with null modem cable and the upgrade software got so far then kept saying wrong file just as i was about to transfer to box .heard some people have done it but with a earlier ops like vista or xp .yep u right about channel list loaded it to another flash drive smaller one 8gb kingston and upgraded another box worked fine .prob just buy another box and flash that
Try this site for recovery tool and firmware if you are getting a file mismatch error www.hddvbsw.com
Here we go again, we are now back to around 535 posts and counting that have been deleted from this thread which 99% contain useless 'Thanks' posts. how many times does this need to be reiterated about posting 'Thanks for this' etc... when all it does is clog the forum.
Can we please use the THANKS button which is located on the bottom left of the Post you want to thank or even just use the LIKE button which is located to just above the Bottom right of the Post, pressing either of these buttons on AJ's latest channel list post which is located here: http://www.digital-kaos.co.uk/forums...ml#post1981894 is sufficient enough and also helps keep this and any other thread similar to this easy to read.
So Please can we keep this thread for general queries and idea's in the future please.
In the meantime i have decided to close this thread for a period of 24 hours which in this time hopefully most members old and new can read this post. Apologies to AJ for the inconvenience.
Would anyone care if I removed the SD channels that are available in HD from the list?
Originally posted by DeejayAJ
I've been asked a few times about an SD list, I've already said I'll make it I just haven't had the time (lazy), I'll make it soon.
Hi Deejay,
Number of reasons why SD is worthwhile.
- known issue with openxbox/skybox of HDMI output failing (I have one thats failed too so have to use scart)
- increased glitching with HD and at busy times reverting to the SD channel has helped which can be treated as a backup
- not all of us have HDMI tv's in all locations of house e.g. bedrooms/conservatory etc.
- HD pairing has begun which means they will be phased out and SD will become more prominent.
Would a SD only list be more upkeep? I liked it how you had it previously where SD channels where just tacked on the end of favourites, i.e. one list. The last version you did that included SD I believe was 01-08-12.
Thanks for a great channel list!
I have used this for some time and update regularly. I have to ask what has happened to the Real time channels on the latest list as they are listed but appear to be dead?
