AJ's Sky UK Channel List **Discussion** Thread
  • DOUGALMCD
    • May 2011
    • 3229
    #1306
    Frequency 11222.17
    Symbol rate 27500
    Polarisation Horizontal
    FEC 2/3
    Same frequency for both channels.
    • beggsy21
      • Sep 2012
      • 76
      #1307
      Originally posted by jimbo 7
      Hi same thing here updated with latest channel list, done it quiet a few times before with no probs ,tp abs file loaded ok did the reboot and just said on the display (LOAD) and is stuck there ,have no idea how to recover the dead box ,thought it can only b a bug in the channel list update if its happened to other people. any help would be great,just done some research and now think it may be a dodgy flash drive
      exactly the same thing here m8, stuck on 'load' after the channel update, looks like my box is bricked....marvellous.
      • boylan
        • Oct 2011
        • 128
        #1308
        There is nothing wrong with the channel list, maybe clone boxes or you have done something different, http://www.digital-kaos.co.uk/forums...-cable-233298/ that will help you fix your box
        • jimbo 7
          • 13
          #1309
          Tryed recovery with null modem cable and the upgrade software got so far then kept saying wrong file just as i was about to transfer to box .heard some people have done it but with a earlier ops like vista or xp .yep u right about channel list loaded it to another flash drive smaller one 8gb kingston and upgraded another box worked fine .prob just buy another box and flash that
          • mahrkpat
            • Jun 2012
            • 510
            #1310
            Try this site for recovery tool and firmware if you are getting a file mismatch error www.hddvbsw.com
            • terryuk22
              • Mar 2009
              • 33
              #1311
              I have uploaded a video on skybox F5 Channel list's if anyone's interested
              https://www.youtube.com/watch?v=w9Tx1IHVzeg to edit fav from fav 1-30 etc
              https://www.youtube.com/watch?v=gs00n7TpLH8 To Install Chan list (Upgrade)
              • genam
                • Apr 2013
                • 176
                #1312
                Originally posted by boylan
                Has Heat (the music channel) changed frequency anybody?
                I'm getting it on 11223 H 27375
                • digicon
                  • 8261
                  #1313
                  Here we go again, we are now back to around 535 posts and counting that have been deleted from this thread which 99% contain useless 'Thanks' posts. how many times does this need to be reiterated about posting 'Thanks for this' etc... when all it does is clog the forum.
                  Can we please use the THANKS button which is located on the bottom left of the Post you want to thank or even just use the LIKE button which is located to just above the Bottom right of the Post, pressing either of these buttons on AJ's latest channel list post which is located here: http://www.digital-kaos.co.uk/forums...ml#post1981894 is sufficient enough and also helps keep this and any other thread similar to this easy to read.
                  So Please can we keep this thread for general queries and idea's in the future please.
                  New members should also take a look at the Forum Rules: http://www.digital-kaos.co.uk/forums...rules-2/#post2 and also this excellent post : http://www.digital-kaos.co.uk/forums...ul-tips-30279/
                  In the meantime i have decided to close this thread for a period of 24 hours which in this time hopefully most members old and new can read this post. Apologies to AJ for the inconvenience.
                  • digicon
                    • 8261
                    #1314
                    Ok Thread now re-opened lets all please use the Thanks and Like button.
                    Thank you
                    • Risan
                      • Apr 2012
                      A few channels not working
                      Originally posted by DeejayAJ
                      Update : 24/5/13
                      Liverpool FC TV
                      Horror Channel
                      CBS Reality
                      Box Nation
                      Racing UK
                      Armchair Shop
                      JML Living
                      DM Digital
                      Zee News
                      TVC News
                      Bon TV
                      4Music
                      Magic
                      thanks aj for this updated list very appriciated bt can u pls check (zee cinema, zee tv, zee punjabi and zee news) are not working.
                      regards
                      • lee11168
                        • Feb 2011
                        • 217
                        #1316
                        what box are you using some of these channels recently moved.do a scan look in allsats and use your remote to move them into the favs
                        • digicon
                          • 8261
                          #1317
                          Originally posted by kittyneil
                          thanks aj worked a treat on my m3 skybox keep up the good work
                          Can you Read see post #1357 if so take note this is now getting beyond a Joke
                          I would also suggest you read this here as well: http://www.digital-kaos.co.uk/forums...ul-tips-30279/
                          • pallys
                            • Jun 2012
                            • 24
                            #1318
                            regards
                            Only Zee News seems to have changed, those rest seem ok for me.
                            • pallys
                              • Jun 2012
                              • 24
                              #1319
                              Would anyone care if I removed the SD channels that are available in HD from the list?
                              I've been asked a few times about an SD list, I've already said I'll make it I just haven't had the time (lazy), I'll make it soon.
                              Hi Deejay,
                              Number of reasons why SD is worthwhile.
                              - known issue with openxbox/skybox of HDMI output failing (I have one thats failed too so have to use scart)
                              - increased glitching with HD and at busy times reverting to the SD channel has helped which can be treated as a backup
                              - not all of us have HDMI tv's in all locations of house e.g. bedrooms/conservatory etc.
                              - HD pairing has begun which means they will be phased out and SD will become more prominent.
                              Would a SD only list be more upkeep? I liked it how you had it previously where SD channels where just tacked on the end of favourites, i.e. one list. The last version you did that included SD I believe was 01-08-12.
                              Thanks.
                              • whybrow
                                • Sep 2012
                                Thanks for a great channel list!
                                I have used this for some time and update regularly. I have to ask what has happened to the Real time channels on the latest list as they are listed but appear to be dead?
                                Cheers
