skybox f3 wifi connection problem
  • rockbala
    • Jan 2013
    bala
    i am to not able connect with wifi on skybox m3
    • mossy464
      #107
      I just got the unofficial Wifi dongle with aerial for skybox M3.
      Iv enabled the Wifi and rebooted and when I go to the Wifi manager it just stays scanning and doesnt even find any wireless networks.
      Should it still find networks even if the settings are not changed to just WPA or WPA2?
      • mossy464
        #108
        Still no joy with my wifi.
        After changing the router settings its finding my network but will not connect.
        I've tried all things on this thread. New image, all numeric password, connect via cable first etc.
        This is the wifi antenna im using.
        WIFI USB ANTENNA FOR SKYBOX AND EYEBOX F3 F4 F5 M3 X3 X4 X5 | eBay
        Any other tips?
        This is so frustrating.
        • mirzaja
          #109
          I had my skybox connected via wifi, at first it was giving the timeout message eventually it connected but had problems wit picture freezing or glitchy. Now using homeplugs much better option worth considering.
          • mohmuliadiyusof
            • Mar 2013
            #110
            why i can't download firmware
            • mohmuliadiyusof
              • Mar 2013
              #111
              why every time my wifi connected and i go back to the chanel. the connection lost
              • Nutty34
                • Feb 2013
                • 130
                #112
                Mate wifi on these boxes is absolutely rubbish, if hard wired is not an option then do yourself a favour and buy some home plugs
                Sent from my iPad using Tapatalk
                • smythe
                  • Oct 2011
                  The code for your router has to be 13 digits long for the slybox to work.
                  Just change your key to a 13 digit code and all should be good .
                  smythe
                  • bucharoo
                    • Dec 2012
                    • 20
                    #114
                    Originally posted by spdude1
                    I did the same to check if the dongle is actually working...created a open wifi hotspot from my mobile and it did work..!!
                    Thanks for sharing.. I hope it worked out for skyboxf3 too..!
                    Hi can you tell me how you created a wifi hotspot from your mobile as I waish to do the same from my iphone.
                    • DW190
                      • May 2012
                      • 1263
                      #115
                      This will depend on the type of phone you have and if it supports tethering.
                      • bucharoo
                        • Dec 2012
                        • 20
                        #116
                        iphone 4 with personal hotspot shaded out.
                        • DW190
                          • May 2012
                          • 1263
                          #117
                          Dont have an Iphone myself but if you enable the hotspot and give it a name (ssid) and password you should then see it when the box is set for wifi.
                          Tech Advisor helps you navigate a mobile world using the tech that is always with you. Our expert advice will steer you to the mobile, smart home and streaming products you love, and show you how they can improve your life.
                          • bucharoo
                            • Dec 2012
                            • 20
                            #118
                            How to use an iPhone as a Wi-Fi hotspot: configuring Personal Hotspot - PC Advisor
                            Thanks Dw190 will give it a spin.
                            • akeep187
                              • Aug 2011
                              • 4
                              #119
                              Hi
                              The Issue with wifi connection is down to the fimrware, the newr firmwares dont seem to like the wifi,
                              This is only one i have come across that seems to work,
                              look for f5 and its titled wifi fix
                              regards
                              • dj1978
                                • 61
                                #120
                                try original scooby snacks firmware mate wifi works excellent its based on old firmware too but is very stable on wifi
