skybox f3 wifi connection problem
  • spdude1
    • Jun 2012
    • 81
    #31
    Originally posted by kaisar1
    good guide spdude1.
    Thanks for your comment Kaiser1...just hope it can help skyboxf3 sort his wifi out..!!
    The quickest way to double your money is to fold it over and put it back in your pocket..
    • kaisar1
      • Aug 2009
      • 462
      #32
      Originally posted by spdude1
      My router has Authentication/encryption as wpa-psk...try selecting that and then you might get the option of wpa and wpa2 seperately in your security mode
      This is how it looks like on my router:
      Security
      Broadcast Network Name:Yes
      Allow New Devices:New stations are allowed (automatically)
      Security Mode:WPA-PSK
      WPA-PSK Preshared Key:xxxxxxx
      WPA-PSK Encryption:AES
      WPA-PSK Version:WPA2
      Hope this helps..!!
      attached pic of my router settings.
      • deansluk
        • 7
        #33
        hi pal had some issues with my wifi to on the f3 and m3 ... try this firmware , works a treat for me , also has sky chanel list in perfect order built in , ... not my work btw
        • taff2412
          • May 2011
          • 18
          #34
          communal wifi
          hi my mate lives in a place where they have communal wifi which they log into a page to enter password etc, is there any way the wifi adaptor can work with this as i dont know a way around having to enter password?
          • shosh
            • Jul 2012
            Hi i have an Huawei e585 and ive tried everything cannot get it to connect! anyone have any ideas? Please and thanks!
            • jonny00
              • Jun 2012
              im having time out errors too, i have allocated ip on my router, i have tried dchp, i have tried open security. ahhhhh not working
              • karl1984
                • Jul 2012
                Has anyone been able to get this working with a belkin sky router?
                The only options I have are - WEP or WEP 802.11 or mix of WEP/WEP2. If I choose WEP or WEP 802.11 then my laptop loses wireless connection and it generates a 26-digit key. When I enter the 26 digit key into skybox it errors on invalid ASCII 5 or 13 message.
                • primitiverising
                  • Jul 2012
                  • 7
                  #38
                  Having problems getting wireless to work with BT broadband router. Changed settings to WEP2 only, still timing out. Maybe that Firmware will help but I'm on a MacBook Pro and the dongle is only for PCs. Anyone know how I can get firmware on to dongle via a Mac?
                  • purple8
                    • Jul 2012
                    • 4
                    #39
                    Hi is there a certain Wifi usb that works. or will any with a certain chipset work
                    • beanoz
                      • Jul 2012
                      Im gonna try the latest firmware. Will post if the wifi issue is sorted.
                      • djbosso
                        • Jul 2012
                        Hi from Thailand! I'm also having trouble with WiFi.
                        Should DHCP be on or off?
                        • pcoltas
                          • Aug 2012
                          having same problem - have tried all differnet wifi settings and even tried open hotspot on phone but times out every time.. :$
                          • loncell
                            • 625
                            #43
                            I'm having the same "timeout" connection problem but i'm on vermin with a superhub.
                            in security i have these options
                            WPA Auto
                            WPA2-PSK[AES]
                            WPA-PSK[TKIP]
                            WPA/WPA2 Enterprise
                            WEP
                            Disable
                            I dont have the WPA2 on its own , also, even whwen i disable the security it still gives me "timeout". Anyone on vermin superhub and got it working ? mine is an offical mini dongle as well.
                            • hanne
                              • Aug 2012
                              • 5
                              #44
                              have a skybox M3
                              with wifi usb
                              In the beginning it took some other gewerkt.tot I had put new firmware.
                              everything works except the wifi.
                              when I click I go to Network Wifi. start the box but WiFi - Manager
                              remains in shadow.
                              how can I fix
                              thank you
                              • cs client
                                • Apr 2012
                                • 16
                                #45
                                WPA Auto
                                WPA2-PSK[AES]
                                WPA-PSK[TKIP]
                                WPA/WPA2 Enterprise
                                WEP
                                Disable
                                Hi mate, I have the same hub and same problem as you. If I manage to sort the problem then I'll post the solution, can you do the same as well. Thanks
