Skybox F5 can't connect to internet
  • sb18180
    • Sep 2012
    • 355
    #16
    did you reboot router and box??
    • dark5tar
      • Mar 2013
      • 26
      #17
      rebooted both router and box no use still same. really wondering what is the problem. you~~~~ working means i got internet connection ok isn't it? could be my nline not working on this?
      Oh at last All guys thanks for suggestions. It's mistake from me. I went to back into my emails to see my correct nline. I entered wrong one before..... sorry ,sorry
      • andy91
        • Aug 2010
        • 3583
        #18
        Will be sorry when you get turfed out for cs talk,read the rules.
        Andy
        • Nutty34
          • Feb 2013
          • 130
          #19
          Andy
          Mate I have shared many a thread on here NOT discussing CS with site admin in the same thread
          Posted using Tapatalk for IPad.
          • Nickrow
            • Jun 2013
            Hi I am new to the forum, I have read through the post and tried some of the suggestions such as changing the DHCP to off then back on and restarting the box. I have also checked the connection by trying you~~~~. I am not able to get you~~~~ either, does this mean it is a connection problem? If so what should I check?
            • machofairy
              • Jul 2013
              • 6
              #21
              Originally posted by digicon
              Goto the network setup ethernet click ok turn off DHCP and then Switch it back on come out of the menu and restart the box that should cure it.
              I have had an F3 for a couple of days and occasionally, the lines of ?offline?. Doing what Digicon said works, but not immediately .. I have to turn DHCP off and on a few times as it does not seem to work first time for me. I am wondering if there is a permanent solution to this or what actually causes this problem.
              • P&D
                • May 2010
                • 2686
                #22
                Which connection / wifi or cable
                Which box ???
                No you~~~~ = no internet
                Have you rebooted the router
                Find you IP address with Google on a computer for your router
                On the box goto /menu/network settings/ethernet settins/check your IP address is the same
                • DW190
                  • May 2012
                  • 1263
                  #23
                  Originally posted by machofairy
                  I have had an F3 for a couple of days and occasionally, the lines of ***8220;offline***8221;. Doing what Digicon said works, but not immediately .. I have to turn DHCP off and on a few times as it does not seem to work first time for me. I am wondering if there is a permanent solution to this or what actually causes this problem.
                  If I get this problem of the IP locking I turn the DHCP OFF and enter a static IP, give it a few minutes and turn the DHCP ON again.
                  • machofairy
                    • Jul 2013
                    • 6
                    #24
                    I do not have a static ip. Do I have to enter a real IP or a fake one will do?
                    • DW190
                      • May 2012
                      • 1263
                      #25
                      You enter one thats within the range of your router. Depending on your router it will be something like 192.168.0.1 - 254 or 192.168.1.1 - 254
                      • machofairy
                        • Jul 2013
                        • 6
                        #26
                        Thanks. I will try that if it happens again
                        • Dazzle1
                          • May 2013
                          • 11
                          #27
                          Have you tried plugging your box into the router directly and then make sure your network settings are set to accept Ethernet?
                          If using wifi, make sure you add the password and save the settings. 802.11g is unstable as its based on the environment it is in. So the skybox might just be loosing connection to the box if its on wifi.
                          • mahrkpat
                            • Jun 2012
                            • 510
                            #28
                            If your router is set to auto channels or on a higher setting than 11 manually set to something lower, setting it to 6 seems a good option, these Chinese boxes seem to have a better connectivity on the lower channels, don't know why though.
                            • aishtiaq
                              • Jan 2014
                              Hi I bought skybox f5s. But youtoube is not working on it. I checked the Ethernet connection, its green. But its not connecting to internet. Pls can anyone help me.
                              • southpaw
                                • 2233
                                #30
                                Try to enable dhcp in the network settings mate
