Thank you . sky sports ashes now in hd.
Cwaite Sky Numbered Channel List **Discussion** Thread
have up dated with new list but cant get
ss 1 hd
ss ashes
ant a lot more just says no signal but box works ok on other channels I'm using a f5 if it was tuner then would all channels be no signal not sure if they have changed the frequency agen to crack us all upComment
On the 4th July Sky HD Odered TP_Prog.dbs Update.zip the 101 to 105 channels are SD correctly but where the HD versions should be, they are also SD. For example 141 should be bbc 1 hd but is the sd one etc.
Thanks for all your hard work.Comment
You Don't have to select favourites as these are full channel lists. If you have a look here Sky Guide TV Listings - Sky
there is a number under the channels, press this in to your sky box and the correct channel will come on.Comment
If you tune to the channel thats not working and press the info button on the remote control 3 times, you will have a screen that comes up that lists the transpoder details:
Sky Sports 1 HD (11798/H/29500)
Sky Sports Ashes HD (11720/H/29499)
if the details are the same the channels are correctly setup on your box.Comment
Channels updates 5/7/2013
Sky HD Ordered lists only needed updating today, Full HD lists still up to date. (Channels were put in wrong place on Sky HD List)
Sky HD fixed Channel list:
BBC1 HD Channel 141
BBC2 HD Channel 142
ITV HD Channel 178
Channel 4 HD Channel 230
Channel 5 HD Channel 171Comment
hi lads
im using skybox f3 firmware (3601HD_10_05_2012_073A) i deleted my old channel list then downloaded 5th July Sky HD Odered TP_Prog.dbs Update.zip list extracted file and put it to root of usb stick,
went to tool, upgrade by USB, upgrade mode (music files), select and upgrade(TP_PROG.dbs) then upgraded it and when i check info i get file not found. ANY HELP PLEASEComment
[QUOTE=mrcooke;2021836]hi lads
went to tool, upgrade by USB, upgrade mode (music files), select and upgrade(TP_PROG.dbs) then upgraded it and when i check info i get file not found. ANY HELP PLEASE[/QUOTE
reformat usb stick in fat32 I had same problem mine was formatted in ntfs,reformatted fat32 put file back on stick and went onto f3 straight away,remember to put tick on tp_prog.dbs by pressing ok and then yellow button to upgrade..Comment
usually you would not have to delete old channel list,as the new list that you are installing will over write old list,try deleting channel list and do a blind scan,then try re-installing tp_prog.dbs
into box and if it goes in reboot box and it may work.Comment
if you delete your old channel list DO NOT DO A BLIND SCAN. I did a blind scan last week and then put a channel list on and bricked my box. I rang the box supplier and he walked me through the steps using a rs232 cable to reflash the box connected to a pc. he explained to me that doing a blind scan then installing a channel list can and will in most cases brick the box. mine is now fully working again. I now delete the channel list that is installed then switch box off then turn back and install new channel list then switch off then back on and all is ok. if you get a corrupted favourites list that shows movies in for example kids you have to do a factory reset which is in tools then switch off then turn back on and install favourites list again and they will show in the correct orderComment
Hi MrCooke,hi lads
Just check to make sure that the file TP_PROG.dbs is not in CAPS at the end ie TP_PROG.DBS as it wont reconize it. The file extension should be in lowercase buddy.
Regards Tony
Humax FoxSat-HDR
Great HD/SD Box with 500GB HardDrive
Manhatton HH-120 42E-30W
Triax 88cm 0.3db
SKYBOX F3
HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
Intel Core i7 [email protected]
MSI R7970 Twin Frozr Boost EditionComment
