Cwaite Sky Numbered Channel List **Discussion** Thread
  • sickswan
    • May 2013
    • 43
    #16
    oh right, ill give it a go! cheers
    • nathan2201
      • Sep 2009
      it`s a great list but bbc1,bbc2,itv1,channel 4 and channel 5 are only sd channels. if hd could be added it would be much better
      • boylan
        • Oct 2011
        • 128
        #18
        If this keeps getting updated then this thread deserves a sticky, or make a new thread with all the junk gone
        • rich1986
          • Jun 2013
          #19
          Originally posted by sattv5
          Moved Frequency Channels updates 29/6/2013
          Bt Sport 2 Channel 446 Moved frequency
          Trace Sports Channel 442 renamed Trace Spt Stars
          I have added 2 more Channel lists which are Full HD ordered and have the following Channels higher up the EPG as
          requested
          BBC 1 Channel 141 Moved to Channel 101
          BBC 2 Channel 142 Moved to Channel 102
          ITV Channel 178 Moved to Channel 103
          Channel 4 Channel 230 Moved to Channel 104
          Channel 5 Channel 171 Moved to Channel 105
          Great list. I think it should be added as a sticky. Im using this all the time now. fast updates and great being in sky order.
          • randy46
            #20
            channel list
            requested
            Your channel list is fantastic, definitely the best around. Keep up the good work
            • digicon
              • 8261
              #21
              Hi All,
              As Requested sattv5 Channel list is now a sticky, so lets try and keep it organised by not asking silly questions and that members will then be able to find the latest channel list easier instead of trawling through pages of thanks posts.
              Please remember to use the Thanks and Like tags instead of posting.
              Regards
              • freakazoid789
                • Dec 2010
                • 89
                #22
                Thank you so much!! Iv made lists before and i appreciate it have being done!!
                Was going to do it the long way, rescanning old channels
                • preditor
                  • Nov 2011
                  • 82
                  #23
                  Hi, what's the difference between the HD ordered and the FULL HD ordered ? Thanks
                  Discussions about cardsharing are not allowed...
                  Discussions about hacking or modifying cable company equipment will be removed.
                  • sattv5
                    • May 2013
                    • 376
                    #24
                    The Sky HD Channel list has BBC1, BBC2, ITV, Channel 4 & Channel 5 (Channels 101 to 105) as the SD Versions
                    The Full HD Channel list has BBC1, BBC2, ITV, Channel 4 & Channel 5 (Channels 101 to 105) as the HD Versions
                    everything else is the same.
                    • MonsterSquad
                      • Jun 2013
                      • 38
                      #25
                      Can I individually add the changed frequency channels instead of updating the list all the time?
                      Sent from my GT-I9305 using Tapatalk 4 Beta
                      • bb5
                        • Aug 2008
                        • 13
                        #26
                        any irish channels ont his for ireland like rte 1 on 101 rte2 on 102 and so on?
                        • willbert
                          • May 2013
                          • 11
                          #27
                          Wow put you and aj together and we have an excellent team of people who can really make beasts of lists
                          • sattv5
                            • May 2013
                            • 376
                            #28
                            The lists are set up for the english version of Sky but the Irish Channels can be found on the following numbers, as well as having there own category in the favourites list.
                            Channel 1065 RTE One
                            Channel 1066 RTE Two HD
                            Channel 1067 RTE Two
                            Channel 1068 RTEjr
                            Channel 1069 TV3
                            Channel 1070 TG4
                            Channel 1071 3e
                            Channel 1072 UTV
                            • ts398im
                              • Jul 2013
                              #29
                              hi sattv5, have just updated box with lastest tp prog , I noticed that sky sports ashes is now in sd form.
                              • goldberg
                                • Jul 2013
                                • 18
                                #30
                                Thanks - will give it a go
