Cwaite Sky Numbered Channel List **Discussion** Thread
  • Kristo32
    • Sep 2012
    • 22
    #301
    Hello, sorry if this is te same thing everyone is asking but after 4th Oct update I can't get RACING UK or AT THE RACES.
    Everything else I use seems fine. I have 3 other people I know with the same issue.
    could anyone offer a solution or even reason??
    • colinwallace
      • Mar 2013
      #302
      Hi could you please add in Setanta ireland to the Sports Section it only shows up in All Channels at the moment and was in sports until latest list
      Thanks for your time
      • rwebster
        • Oct 2013
        This has sorted out a newbie nicely. Followed skytv5's instructions with the favourite settings and i worked a treat
        • sattv5
          • May 2013
          • 376
          #304
          Originally posted by out7aw
          can anybody tell me the difference between the 4 channel lists uploaded? i am not sure which
          one i need.
          Full HD:
          BBC1, BBC2,ITV1,Channel 4,Channel 5 at channels 101-105 are the HD Versions
          the SD Versions are at BBC 1 SD 141, BBC 2 SD 142, ITV1 SD 178, Channel 4 SD 230, Channel 5 SD 171
          Full HD No Adult:
          Exactly The same as Full Hd except all adult channels have been removed
          Sky HD:
          BBC1, BBC2,ITV1,Channel 4,Channel 5 at channels 101-105 are the SD Versions
          the HD Versions are at BBC 1 HD 141, BBC 2 HD 142, ITV1 HD 178, Channel 4 HD 230, Channel 5 HD 171
          Sky Hd No Adult:
          Exactly The same as Sky HD except all adult channels have been removed
          Originally posted by kenchov
          could someone tell me where the updated channel list is?
          Sorry forgot to put the link at the bottom of the post
          I will take a look in a bit at the list as those channels are working fine here, it could be something as simple a
          me using the wrong version of the channels (commercial) instead of domestic ones
          UPDATE: there is no commercial versions of these channels and the details are correct for the UK, there is only an irish alternative to attheraces and if I swap that channel out it would cause more problems than it solves.
          Yep no problems, I must have accidently forgot to add it back there
          • bbb_uk
            • 429
            #305
            Originally posted by sattv5
            There's still 6 more transponders to shut down between now and the 10th october.
            I avoided using any of them transponders when updating the channel lists so we don't have to worry about it
            Any chance you could post the 6 transponders that should be avoided due to shut down, or direct me to where this info is?
            Thanks again.
            • joe516
              • 1000
              #306
              Thanks again.
              11469H off
              11488V powered but no channels
              11508H off
              11527V powered & carrying 10 services
              11604V off
              11623H powered & carrying 13 services
              11662H powered & carrying 13 services
              11681V powered & carrying 14 services
              12523H off
              12523V powered & carrying 30 services
              12560H powered & carrying 6 services
              12560V powered & carrying 19 services
              12607H powered & carrying 16 services
              12607V powered & carrying 31 services
              12643H powered & carrying 11 services
              12643V powered but no channels
              information given is to be used for educational purposes only
              Don't Forget To Say Thanks If You Like My Post
              IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
              If It Ain't Broke Don't Fix It
              • genam
                • Apr 2013
                • 176
                #307
                i can't get Heat or Magic TV channels ..363 and 364... says no signal.. has it moved or is it off ... was there a few days ago
                • mahrkpat
                  • Jun 2012
                  • 510
                  #308
                  Need to update channel list lot of channels are moving about maybe a week or more before things settle down again.
                  • bbb_uk
                    • 429
                    #309
                    As mahrkpat has said, lots of channels have changed.
                    Mine still works on transponder 11221/H. To double check your transponder click info twice on the Heat or Magic channel.
                    If the first half of your transponder doesn't match above then download either AJs or Sattv5 channel list (see stickies on this thread) depending on which channel list your currently using which it sounds like it's Sattv5's.
                    • sattv5
                      • May 2013
                      • 376
                      #310
                      Any chance you could post the 6 transponders that should be avoided due to shut down, or direct me to where this info is? Thanks again.
                      10979 V 22000 >>>>>>>>12515 H 22000
                      11082 H 22000 >>>>>>>>12522 V 22000
                      11112 H 22000 >>>>>>>>12552 V 22000
                      11141 H 22000 >>>>>>>>12581 V 22000
                      11156 V 23000 >>>>>>>>12574 H 23000
                      11171 H 22000 >>>>>>>>12545 H 22000
                      (red ones are closing down the other ones are where they have gone)
                      The channels from these are complete duplicate transponders, instead of moving each individual channel just change
                      the details of the transponder in the channel list and then theres only 6 changes to make
                      I will move the Heat & Magic TV Channel to one of the new transponders, although they still work on the frequency
                      there on (11221 H). They are both on 3 different transponders at the moment still.
                      • sparky18779
                        • May 2013
                        #311
                        prime time returns no signal
                        • sattv5
                          • May 2013
                          • 376
                          #312
                          I have checked again and the channels on the other transponders are the radio versions of the missing channels, so i am not sure why they are not working for you on the existing frequencies as they are FTA channels anyway
                          Moved Frequency Channels Updates 06/10/2013
                          Primetime (Channel 498) Changed Frequency to 12640 V 22000 (sid 55245)
                          Setanta Ireland (Channel 423) Channel was missing from Sports Favourites
                          Premier Sports (Channel 428) Channel was missing from Sports Favourites
                          ***panded Tv (Channel 931) Changed Frequency to 12581 V 22000
                          ***cess (Channel 923) Changed Frequency to 12640 V 22000 (sid 55248)
                          Sukh Sagar (Radio Section) removed as Duplicate
                          Capital XTRA (Radio Section) removed as Duplicate
                          • mikeydavies
                            • Aug 2008
                            • 6
                            #313
                            I don't usually post or ask for much as I can usually work it out for myself! Anyway, after updating to the latest sattv5 list I've noticed that the all channel favorite seems to have disappeared and i'm now finding it a nightmare to find anything due to not having a full sky number listing! Is there any chance that this can return please as I really miss it and don't use the other favorites! Thanks in advance.
                            EDIT:- Don't worry, I got it now, I was thinking about Pellonet's list. I'd completely forgotten who i'd got the original list from until now! Anyway, I read the main list page and found out what to do so for anyone else who's lost you need to click on OK, then click the red button and select all in the little menu that pops up (It will look like the channels have disappeared but don't worry, they haven't!). Then when you exit out of the lists to go back to viewing you'll have a SKY ordered list to work with!
                            • tony2803
                              • 266
                              #314
                              sky living+1 and sky livingit+1 am I wrong or are these two channels not in the correct sky order.as living+1 is not on 123.
                              • sattv5
                                • May 2013
                                • 376
                                #315
                                Sky Livingit + 1 on (Channel 223) is correct
                                Sky Living +1 (should be on 123) Missing channel accidently duplicated sky livingit +1 here
                                Will update with other updates later, just waiting to see if any other changes today.
