Cwaite Sky Numbered Channel List **Discussion** Thread
Can you tell me what message you get when you tune to SS2 on channel 403? Also can you tell me the channel name of channel 2 this should be a set of numbers if you are using a recent cwaite/sattv5 list?
Also do you have any other satellite boxes connect to the same dish as the box you are having trouble with, if so then please disconnect these from the mains (unplug them from the power) then see if you can get SS2 on channel 403.
As per my message on 19th September can you tell me the channel name of channel 2 this should be a set of numbers if you are using a recent cwaite/sattv5 list?
cwaite cheers for ur list,
i just edited a few for my pref.(deleted all the skipped channels & moved BBC1 NI HD, UTV HD)
i have to update a couple of friends now
