Skybox F5
  • der01
    • Sep 2013
    • 17
    Skybox F5
    Try as I may I just cant get this box to flash is there anybody that can repair the box for me
  • darcu5
    • Jun 2011
    • 944
    why are you trying to re-flash the box?
    • bbb_uk
      • 429
      More info needed really like what you trying to reflash and where from and what message you getting?
      If it's firmware and you're getting mismatch message then visit this thread.
      • der01
        • Sep 2013
        • 17
        The box just keeps on loading all the time I have tried everything to flash it but no joy
        • P&D
          • 2686
          Have a look here The short version to recover a dead or stuck in load box 95% of questions answered
          • der01
            • Sep 2013
            • 17
            my box says synchronizing stbs and please reset target and then it does not move and I found my com port is 1 and my bit rate is 9600 so I have set it at that and I have tried the two upgrade files and I have checked that I have the correct cable so I don't know what else I can do.
            • bbb_uk
              • 429
              Did this happen shortly after a channel update, firmware update or just randomly as far as you're aware?
              • P&D
                • 2686
                Which firmware file did you use ???
                the one in my post or another one ??
                • der01
                  • Sep 2013
                  • 17
                  In reply to BBB_UK it happened after channel update, and for P&D i have tried all sorts of firmware but still no good
                  • der01
                    • Sep 2013
                    • 17
                    The box is working at last by borrowed an old XP pc and it worked thanks for all your help
                    • carpettony
                      • Oct 2013
                      • 9
                      Not always a good idea to keep re-flashing.I'm told it can cause problems at the other end of your phone line ?
                      Or can someone correct me on that 'myth' ?
                      • P&D
                        • 2686
                        Not quite sure what you mean ???
                        when you flash the box....its only connected to the computer & power cable
                        • bbb_uk
                          • 429
                          It sounds like the channel list was problem.
                          I know you're sorted now but I'm sure I read that Sattv5 said it may be possible in cases of the box rebooting to press menu (prob before box tries to use channel list) which then delete channel list.
                          • lollygagger
                            • Oct 2013
                            • 11
                            How did you do it buddy, I am still having problems......
                            • cgscott
                              • 3513
                              The moral of this thread is dont buy skybox f5's. they are shite.
                              Patience is a virtue.
