Help trying to set up new box
This topic is closed.
  • nic2369
    • Oct 2013
    • 7
    Trying to set a new box up in my sons room
    when entering cline its either saying offline or when i re enter saying online/login?
  • Hadron
    • 2102
    Are you using a wired ethernet connection, or wireless?
    • nic2369
      • Oct 2013
      • 7
      hi using ethernet cable
      I have another box that works fine on the cables this box is going into. new box is receiving free to air channels, i have contacted provider just wasnt sure if i had installed incorrectly
      • paul93
        • 50
        you need to reboot the box if it says offline or login or delete line and entre again and reboot the box it will work if the line is ok.
        • nic2369
          • Oct 2013
          • 7
          ok have tried this a couple of times and have used line provider before and check with them line is fine so how many times could it take for it to work?
          • spagbol12
            • Sep 2013
            • 46
            hi ive just had same problem are u putting in manually or by usb? because I coundnt get it to go on online until they sent it as an e mail attachment and I put it on via usb .. hope this helps
            • nic2369
              • Oct 2013
              • 7
              manually so will ask for it in email attachement
              • P&D
                • 2684
                1 sealion =1 box
                2 sealion's =2 boxes
                you cannot run 2 boxes at the same time
                • nic2369
                  • Oct 2013
                  • 7
                  im not trying to use 2 at same time, im trying to set up another box for a friend using my internet for its only a matter of connecting at their house and the codes not coming online and ive been advised by provider its on at their end?
                  • spagbol12
                    • Sep 2013
                    • 46
                    u need to ask them to send it as attachment e-mail U then go on utube and see how to put it on ...ps there is a way for you to put straight to usb pen but first way quicker and easier ..GOOD LUCK
                      Closed Please read the forum Rules again: http://www.digital-kaos.co.uk/forums...rules-2/#post2
                      Any mention of the following words Server,Line,provider etc.. are in breach of this rule as they all relate to the same subject:Discussions about cardsharing are not allowed, including, but not limited to, cccam, gbox, mbox, etc
