I have another box that works fine on the cables this box is going into. new box is receiving free to air channels, i have contacted provider just wasnt sure if i had installed incorrectly
ok have tried this a couple of times and have used line provider before and check with them line is fine so how many times could it take for it to work?
hi ive just had same problem are u putting in manually or by usb? because I coundnt get it to go on online until they sent it as an e mail attachment and I put it on via usb .. hope this helps
im not trying to use 2 at same time, im trying to set up another box for a friend using my internet for its only a matter of connecting at their house and the codes not coming online and ive been advised by provider its on at their end?
u need to ask them to send it as attachment e-mail U then go on utube and see how to put it on ...ps there is a way for you to put straight to usb pen but first way quicker and easier ..GOOD LUCK
Any mention of the following words Server,Line,provider etc.. are in breach of this rule as they all relate to the same subject:Discussions about cardsharing are not allowed, including, but not limited to, cccam, gbox, mbox, etc
