Can't solve epg being 1 hr out??
  • jonc26uk
    • Mar 2014
    • 4
    Since the clocks went forward the epg is now an hour out, have tried reformatting stick in computer and then reloading epg but it's still one hour behind, can anyone help?
  • bigade1
    • Oct 2013
    • 340
    Enter the menu and navigate to " Epg and Time Setting " and turn the Summer Time setting to ON.
    • jonc26uk
      • Mar 2014
      • 4
      Already done this, time is correct but epg is still an hour behind
      • katieb
        • Feb 2014
        • 63
        why have the clocks changed again? thought it was still winter
        • bigade1
          • Oct 2013
          • 340
          Have you tried a reboot?
          • jonc26uk
            • Mar 2014
            • 4
            Yep tried that aswell!
            • cactikid
              • 12017
              and you loaded old epg,why not try a new epg since your time setting are now correct.
              • jonc26uk
                • Mar 2014
                • 4
                I sorted time first, then I rebooted the skybox, I also took out usb stick and reformatted it on the computer. I then reloaded the epg onto the freshly formatted stick but it's still one hour out??
                • dilzy2
                  • Feb 2014
                  • 26
                  EXACT same problem here its doing my head in
                  • dpm1980
                    • Mar 2014
                    • 20
                    Me to so annoying my clocks right when I put summertime on reloaded epg and all still an hour out grrrr
                    • dilzy2
                      • Feb 2014
                      • 26
                      Anyone please help us out?
                      • DW190
                        • May 2012
                        • 1263
                        Just set the time to UK By Region
                          Realistically the box is programmed into the world clock any changing accrue from menu will have to be forced by technical way.
                          • middots3
                            • 194
                            Same here, any solutions?
                            • Slywalker
                              • Aug 2013
                              • 12
                              The time is correct on the system and the epg is off by an hour, altering the time by an hour or even two makes no difference so the epg appears to be separate from the system clock so I figure the issue is with the xmltv file but I can't find it on my HDD to look at it, just did an update and looked at the files again and there is nothing with a modified date of today - what is the file called and how do you edit it?
